MMI Media Hard Drive
Does MMI in Q5 has internal hard drive for music file storage? I am waiting for my Q5 order to arrive coming from Mercedes GLC which has hard drive that I use to copy my music to.
I found it was easier to load music (and you can add more) using an SD card. There are 2 slots in the dash which the MMI will directly play from.
You can use a USB stick as well, but it uses up the armrest USB port so you cannot connect to carplay/android auto while playing music (hence the SD card suggestion).
Plus one with SD card option. Easy to move around between cars and to modify your tunes than the hard drive.
Thanks guys. Looks like SD card is the way to go as it makes it more convenient.
snagitseven
A4 (B8 Platform) Discussion
12-25-2008 02:28 PM
