Navigation favourites : how do I rename?
Hi,
this is my very first article here, so first of all... Hi everybody ! Now... going to my first topic: I'm able to add navigation favourite but... how do I rename it? I see it in the list like "street nb xx City yyy" but... can't I setup it as "Mattew's home" for example? Is there a way to do so ? Thank you |
I also could not figure out how to do this. Our previous Q5 (2019) had that capability, but our 2022 does not let you change the name (apparently).
We asked the dealership (several times), and they claim that it can be done, however, they could not do it. I then called Audi of America, and was told (today) that "that feature has been removed". I can't believe something so basic "has been removed". If you find out how to do this, I'd very much like to know. Good luck (to all of us!) |
Originally Posted by pcrespi
(Post 25684058)
Hi,
this is my very first article here, so first of all... Hi everybody ! Now... going to my first topic: I'm able to add navigation favourite but... how do I rename it? I see it in the list like "street nb xx City yyy" but... can't I setup it as "Mattew's home" for example? Is there a way to do so ? Thank you Note that on the MMI, if you have the Favorites view up, you’ll have to navigate away and back to favorites to see the change. Also note that if you have an address that you renamed currently saved as a “Shortcut” in the secondary central convenience screen (climate control), you’ll need to remove it and add it back again. Do this by opening up the shortcuts view (4 squares icon 🔲🔲🔲🔲), long press on any shortcut until the “X” appears, tap the “X” to remove the shortcut, tap “Done”. Bonus: you can reorder them by entering into edit mode (the first long press to get the “X”), then long pressing on the shortcut you want to move and dragging it onto the shortcut you want to put it in front of. Cheers! https://cimg7.ibsrv.net/gimg/www.aud...fd5ecd95a.jpeg myAudi app, view nav favorites https://cimg8.ibsrv.net/gimg/www.aud...fe1ae8958.jpeg myAudi app, edit or rename nav favorites |
I'm using app version 4.24.1 which is the most up to date for Android. The renaming tip above worked well (thanks) but there seems no ability to reorder. A long press only let's you then swipe left or right to delete.
I guess the above images are from an iPhone. |
Originally Posted by Scotty (UK)
(Post 25896657)
