Portable air compressor
hey all, for the the cigarette lighter in the front and rear. I know it’s 12v outlet but don’t anyone know the ax amp and wattage? anyoone got a tire air co press or for their q5? |
Originally Posted by Gizmo607
(Post 25209194)
hey all, for the the cigarette lighter in the front and rear. I know it’s 12v outlet but don’t anyone know the ax amp and wattage? anyoone got a tire air co press or for their q5? EPAuto 12V DC Portable Air Compressor Pump, Digital Tire Inflator by 100 PSI https://www.amazon.com/dp/B01L9WSTEG/ref=cm_sw_r_cp_api_U2hMBbC0T62ZB |
I’m new here only had my sq for a few days but I thought I saw one in the back by the spare tire? |
Originally Posted by Heat00
(Post 25209209)
Originally Posted by katzjamr
(Post 25209255)
Yes Heat you are correct, I have a compressor back there next to my flat spare tire that came with the Q5.
Originally Posted by NeedMoreHP
(Post 25209207)
This comes in a canvas bag and fits perfectly in the side pocket in the trunk. Plus no watching the needle - set it and it’ll turn off once it hits the desired PSI EPAuto 12V DC Portable Air Compressor Pump, Digital Tire Inflator by 100 PSI https://www.amazon.com/dp/B01L9WSTEG/ref=cm_sw_r_cp_api_U2hMBbC0T62ZB |
(Post 25209298)
yes there is but that is for the spare tire. |
(Post 25209207)
This comes in a canvas bag and fits perfectly in the side pocket in the trunk. Plus no watching the needle - set it and it’ll turn off once it hits the desired PSI EPAuto 12V DC Portable Air Compressor Pump, Digital Tire Inflator by 100 PSI https://www.amazon.com/dp/B01L9WSTEG..._U2hMBbC0T62ZB |
There is a thread on storage. I use a Husky bag that works really good. Compact and holds a lot of stuff. Removable.
https://www.audiworld.com/forums/q5-...2942079/page2/ As to the OP. I have no idea what the amperage rating of the 12V accessory plug is. In my experience any decent compressor needs to be hooked directly to the battery for current draw reasons. I'd wire up a SAE plug pig-tail directly to the battery since its back there to mate up to my desired unit. |
Originally Posted by Rustydog
(Post 25209415)
https://www.audiworld.com/forums/q5-...2942079/page2/ As to the OP. I have no idea what the amperage rating of the 12V accessory plug is. In my experience any decent compressor needs to be hooked directly to the battery for current draw reasons. I'd wire up a SAE plug pig-tail directly to the battery since its back there to mate up to my desired unit. thanks. i see what you have, that works, however I might go with a hard box from home depot, not sure why lol... will find something there I guess. Funny, I have the same list of items that I probably never will need but feel I have to have with me. to be fair some items are for work, flashlight, wheel, measuring tape, light tools etc. and I have used my plug kit and compressor at least twice in my lifetime so I guess it's worth having all that stuff in there LOL... |
