Q5/SQ5 Reported Issues and Fixes
#11
dealers are able to fix this? i get this issue about a third of the time but the dealer wasn't able to replicate and the SA was saying it would primarily be physically adjusting the wiper which would potentially mistime the left and right wipers.
#13
I would love to make this change if it is available on the 2018 Q5. Does anyone know if this has been figured out yet? Thanks!
#14
Haven't seen/heard anything. Considering OBDEleven does it with the excessive A/C load method, I'm assuming it no longer exists on the newer models.
#16
I have not been able to program the Home Link system to operate my garage door....that is until today. The roadside assistance tech said there is a conflict between the Pre-Sense and/or Active Lane Assist that prevents the Home Link system from picking up the frequency of the opener. He unplugged the brown wiring harness plug behind the left rear wheel well panel then - voila - it picked up the opener frequency immediately and we were good to go with the rest of the steps. Reconnected the harness and that was that. Audi is supposedly working on a fix. It is just some openers - ones operating in the 315 Mhz range I believe.
pbeiser (09-17-2019)
#17
#18
Just got my first "Steering Wheel Heater Malfunction" the other day, I have not modified it at all with OBD. Sometimes the heat doesn't seem to be on some days it is. I'll probably complain with my next visit to see.
The overhead graphics resetting are annoying for sure - I should be able to have overhead + front/back view when I want. I'd also love a better
The engine things like Turbo lag are basically the "polite" mode on the 2.0 and Sport Mode will both cure it and drain your tank, so quite literally YMMV. Start/stop, I've never figured out why it starts randomly when I'm at a long-*** stoplight, but other than a moment's hesitation at a green light it's fine, same as literally every other "auto stop" I've had in a car.
#19
Hello All! First time Audi owner here, just bought a used 2013 Q5 recently and I've already had a couple issues & would love some insight...
1. My "Adaptive Headlight: Defective" error light is always on now. I'll pull the headlight out when I get some free time this weekend, but in the meantime through research online it seems as if others have had this same issue with other Audi vehicles. Some possible cause/fixes I've come across are a broken wire inside the headlight from the movement, a bad light bulb causes the error code, or the adaptive motor inside the headlight needs replaced. Anyone with a Q5 have this issue yet?
2. Today my panoramic sunroof decided to not close all the way. I can rotate the **** and it will open all the way just fine, but when i rotate the **** for it to close it slides all the way forward but doesn't drop down to the closed position, it stays tilted up. When I try to push up & pull down the **** lip to make it tilt up or back down to close, I hear a faint electronic noise like its thinking or wants to work but it just doesn't. I've tried getting out of the vehicle and inserting the key into the door holding into the lock position which triggers all the windows to close and this works for the windows but not my sunroof. When I get home tonight I'm going to try and take a closer look and even try cleaning/lubing the track to see if that works. I even read somewhere about finding the fuse & pulling it & then re-inserting it. Have any other Q5 owners had any issues?
3. I happened to come across some forum pages where people have said don't disconnect the battery or else your stereo/navigation (MMI system I guess it's all called) won't work? Something about you need some sort of serial number or passcode thats located on the back of the radio or something? Is this true?
