Q5/SQ5 Reported Issues and Fixes
#51
You may also want to check if the other fob is in the car somewhere, such as in a bag. I experienced some really flakey and inexplicable behavior when I had the extra fob in my bag in the bag of my car and it would randomly not lock or fold the mirrors.
#52
Weird sound when opening driver side door
2018 SQ5 not sure if this is a problem, but car is brand new and since leaving the dealership there is a high pitched computerized sound upon opening diver side door. I can’t find any information in manual describing the occurrence of any such sound, but I assume this is normal and there is an obvious reason for it. It does not happen all the time and it is definitely not a squeak from the door. Any info appreciated. Thanks
#53
#55
It is the fuel pump. The fuel rail needs to be fully pressurized due to the direct injection. If you leave the car powered on for a bit, the cycle will repeat to ensure the fuel rail is fully pressurized.
BMW does the same, just a slightly different sound.
#57
Audiworld Member
I need to try the garage door trick. I've had mine about 2 months now and I've had the remote that comes with the opener clipped to my visor, because I could not get it programmed. First time in all my years that a car would not learn this crap. Rather annoying.
#58
Don't know if it affects garage door programming, but I found range severely impacted when I changed our light bulbs with LEDs. When the LEDs are on, they interfere with the signal. I would have trouble after pulling out of the garage trying to shut it, but it would work fine coming home and opening because they were off.
possible the LEDs would interfere with the pairing process.
#59
its the fuel pump, it makes the sound every time I open the door, doesn’t matter which door it still makes the noise. I noticed that when I first picked up the car. And the dealer told me that every s model car makes that noise. Normal
#60
I had the tailgate open yesterday while the car was out in the rain. I could be that the button on the fob got squeezed while in my pocket.
Can I and if so, how do I do this?: Increase time required to open trunk lid with remote key
Central Module Comfort System (46) > Adaptation > Time for opening rear lid with remote control > default 800 (ms) > change to desired value (e.g. 2000 = 2 seconds)
Do I have to get the dealer to do it for me?
