Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
Sportcomputer
Old 02-20-2019, 07:47 AM
gasoline's Avatar
Default Sportcomputer
Hallo,
Hat schon jemand den Sportcomputer codiert ??
mfg gasoline
Old 02-22-2019, 05:55 PM
Wires's Avatar
What do you mean "sport computer"? You can code your car, if that's what you are asking. Tons of threads on the B9 platform coding.
Old 02-28-2019, 10:26 AM
gasoline's Avatar
Weiß jemand was für ein Sensor und wo freigeschaltet werden muß,das es funktioniert.
mfg gasoline
Old 02-28-2019, 02:47 PM
Wires's Avatar
Your post makes no sense.
Old 02-28-2019, 09:31 PM
gasoline's Avatar
Im Steuergerät 17 über die Lange Codierung Byte 10 > Bit 2 auf 1.
Dadurch wird der Sportcomputer freigeschalten, bleibt jedoch ohne Funktion. Eventuell muss noch an einer anderen Stelle der richtige Sensor freigeschalten werden für die G-Kräfte Anzeige
Morgen,das meine Ich.
mfg gasoline
Old 03-01-2019, 03:45 AM
Wires's Avatar
I see what you mean. Yes, you can code that on the Q5 platform, but on my 2018 SQ5 it didn't work fully. The G-meter did not work, the lap timer did work. Maybe the newer MMI update fixes that as well, but I'm not sure.
Old 03-01-2019, 04:28 AM
Glisse's Avatar
He has already coded the MMI to show (RS) Sport view, but the G force sensor display isn't active, and is trying to determine whether there is additional coding required to enable this. On B9/FY series the G force sensor has a physical connection to the central chassis control unit but have no idea whether MMI coding can actually obtain the data. I doubt it.
But if he can't spend 20 seconds using Google translate to put his posts in (a sort of) English, in an English language forum, then it's hard to take him seriously. Although choosing gasoline as a user name was quite funny given his car is clearly a diesel.
Old 03-01-2019, 05:03 AM
gasoline's Avatar
Hello,
Excuse me for my German
but my car is an SQ5 gasoline engine and not a diesel
mfg gasoline
Old 03-01-2019, 05:05 AM
gasoline's Avatar
That was just an example from Google
Old 03-01-2019, 05:25 AM
Wires's Avatar
The g-force never worked for me when I coded it, so I don't think it is supported on the B9 platform.
Hillbilly
01-14-2008 02:12 AM
MontanA4
10-29-2002 09:51 PM
RangeR BoB
01-12-2000 01:14 PM
Fred Kern
01-08-1999 10:04 PM
Quick Reply: Sportcomputer
