Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Sponsored By:
Sponsored By:
2006 Audi Q7 TDI white smoke
Old 05-02-2019, 04:24 AM
Default 2006 Audi Q7 TDI white smoke
Hi there experts. I need help with my 2006 audi q7 3.0 tdi. Lots of white smoke coming out of my exhaust. Recently i sent it the my local workshop but they could not find what is the fault. They replaced the oil seperator valve, diesel injectors working fine and turbo working fine. Other than that, my reverse camera is not working, A/C is not working, cd changer not working.
I read online, it could possibly be a weak battery. I changed my battery but did not recode it.
I bought a vag401 scanner and found 4 fault codes
please i am desperate for help. I have spent thousands and going in and out from workshop.
Archie Omar is offline
Old 05-03-2019, 01:54 PM
you replaced the battery without getting it tested?
If its not the same CCA and AGM if it was agm etc than the one you had you just created even more problems to come.
The voltage regulator isnt going to have any idea you replaced the battery without changing the code to ANYTHING else, so its not going to do anything different, if its a different CCA then its not going to charge it fully and makes things much worse.
now for the white smoke,
Is there too much oil in the engine?
Did this shop do a compression test???? or they just checked for codes cuz that's exactly what a real mechanic is going to check for an engine thats burning oil or worse coolant... sarcasm.
Is your coolant low?
Did the shop check your sparkplugs for signs of burning oil or coolant in each cylinder??? this would be part of the compression test since that requires pulling each plug...
bspurloc is offline
Old 05-03-2019, 01:58 PM
also....
have you checked the spare tire area for water??? being a 2006 your roof drain rear right almost 100% have to be leaking onto the boss amp by now unless someone fixed it.
bspurloc is offline
Old 05-05-2019, 10:12 AM
For the battery, recode it and then clear faults. Is the white smoke all the time at all engine temps? How does it feel? Power? Acceleration? Smooth or rough? Abnormal sounds?
Dudeness30 is offline
Old 05-11-2019, 09:17 AM
Originally Posted by bspurloc View Post
also....
Thank you very much for reply. I have sent my car to another workshop. I will definitely give these points to the mechanics there to have a look. Tomorrow they will do a compression test.
As for leaking, we found the front passenger was wet jist under the floor mat. Will have a look at the spare tire area
Old 05-11-2019, 09:26 AM
The white smoke is all the time. Lots of it too. Temp normal at all time. I cant really tell the difference of power and acceleration. Felt the same to me.
But just i about to send the car to the workshop, this warning came out.
I can only drive rpm below 1500.
The mechanics suspects the smoke might it be because of the egr or cat being that the car is an old car. The egr and cat might be very dirty. The also mentioned it could be worn piston rings.
Old 05-11-2019, 09:41 AM
Forgot to mention, the white smoke has diesel smell to it.
Old 05-16-2019, 12:17 PM
xThinG's Avatar
Check the diesel particulate filter, it may be clogged or something, try to clean it. Are you having oil level warnings?
xThinG is offline
Old 05-17-2019, 12:06 AM
Will inform the workshop tomorrow. No sir, i did not get any oil level warnings.
Even the guys at workshop is scratching their heads.
Old 05-22-2019, 06:25 AM
QUICK QUESTION I OVERFILLED MY 2014 AUDI Q% w Oil. I drove the car at low speeds for about 100 yards THICK WHITE SMOKE POURED OUT OF TAIL PIPE. POSSIBLE DAMAGE?
Hawkeye613 is offline
Quick Reply: 2006 Audi Q7 TDI white smoke
