Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2007 Q7
Old 09-18-2017, 04:30 PM
Go Texans!'s Avatar
Default 2007 Q7
Won't crank,headlights dont turn on,Windows won't go down and cluster panel is blank,does anyone have an idea what could be my problem.
Old 09-18-2017, 04:53 PM
dreadlocks's Avatar
The battery is dead
Old 09-18-2017, 04:58 PM
Go Texans!'s Avatar
Originally Posted by dreadlocks;25039
301
The battery is dead
Battery is fully charged.Time,date and mileage turn on on cluster panel.Interior light turn on and radio turns on.Was wondering that maybe a relay or fuse for ignition switch,if so where is it located?
Old 09-18-2017, 05:00 PM
dreadlocks's Avatar
Whats the resting voltage? A Dead battery cant be fully charged, sounds like the only stuff working is the stuff that dont require much power at all.
Old 09-18-2017, 05:04 PM
Go Texans!'s Avatar
Took off battery and had autozone check it and they said it was good,but I still told them to charge it.Plus the battery is new we just bought it like 4 months ago.
Old 09-18-2017, 05:06 PM
Go Texans!'s Avatar
Had no issues with it at all.My wife tried to start it in the morning and nothing.
Old 09-18-2017, 05:10 PM
dreadlocks's Avatar
Did you recode the vehicle and tell it you installed a new battery? The vehicle wont charge the battery to full if you did not do a proper adaption; AutoZone cannot do this. Battery Replacement - Ross-Tech Wiki
Use the jumpstart posts under the hood and see if it'll jump.
Old 09-18-2017, 05:19 PM
Go Texans!'s Avatar
But the new battery was installed 4 months ago and didn't have any issues.
Old 09-18-2017, 05:21 PM
dreadlocks's Avatar
The voltage regulator treats the battery differently as it ages, if you dont tell it you put a new battery in it will never fully charge it.. as it would overcharge an old battery.. so for the last 4 months its been undercharging this, and it'd just get worse over time.. this could damage the battery to the point it wont start your vehicle.
Dont own some jumper cables?
Old 09-18-2017, 05:39 PM
Go Texans!'s Avatar
I connected a power booster to the under the hood terminals and nothing happened.
Quick Reply: 2007 Q7
