2007 Q7 drivers seat getting too hot
Hi guys. This is my first post, hoping for some help from you kind gents.
Basically the drivers heated seat is getting too hot no matter what setting it's on (1 to 6). It's like it's on 6 all the time but once the engine is up to temperature then it's absolutely fine.
VCDS is showing:
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Thanks in advance.
VCDS is showing:
Freeze Frame:
Thanks in advance.
sorry I cant help. but I would check the wiring to the seat isnt dirty or corroding. I believe that will require lifting the seat.
which isnt a big deal if you have the right tools. do not use a TORX to losen the 2 front bolts they are not torx and u will strip them. the correct bit is an M10.
I cover how to lift the seat in my battery change video.
The seat is made to tilt backwards when you remove the front 2 M10 bolts.
Hi there. Thank you for your reply. I will definitely take a look but I will have to remove the seat because mine is UK model.
The wiring loom is new because I had the seats retrofitting. I have another seat to try but if its still the same it has to be the control unit.
enzeder
Wheels & Tires Discussion
03-30-2010 11:01 AM
audidood
10-21-2000 11:29 PM
