2007 Q7 Sound System
Morning all.
Ive recently acquired a 2007 Q7 SLine complete with BOSE sound system, the sound emitted from the system is fine at low levels however when I need to turn the volume up when traveling at speed for example then all the speakers are distorted as if they have all blown, my first reaction was that the wiring had been butchered however a bit of digging suggested that the amp was the issue, Ive sent this away to be fixed (via the garage i purchased from) and they have come back saying there was a small fault but nothing that could have caused the speaker issue so im back to square one, would you have any advice please? I would be surprised if the wiring has been tampered with as the vehicle is pristine but you never know however there was only the one screw holding the amp in suggesting it has been removed previously - your input would be very much appreciated.
Cheers
Chris
Cheers
Chris
I also noticed when trying to fine tune the sound in an attempt to minimize speaker vibration that the speaker balance was not correct, it was inverted so to speak so if I turned down the left the right speaker volume would drop.
Just a bit of background, I bought the car from 2nd hand dealer in Wigan, they did initially offer to replace the amp but after some delay in sourcing one (I think the travel distance to get it checked themselves & cost of a replacement amp put them off) they decided to get mine repaired and asked me to send it up to them, but again based on the information Ive had back from them there appears to be no direct fault in the amp, Ive no idea who has tested it as they outsourced this but will ask the question but i think im now being fobbed off unfortunately.
Again thanks for your reply.
Rocky-in-Connecticut
Q5/SQ5 MKI (8R) Discussion
05-06-2008 04:15 AM
