Go Back  AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 / Q8 > Audi Q7 > Q7 Discussion
Reload this Page >
Is the 2007 TPMS active or inactive?
Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Sponsored By:
Sponsored By:
Old 04-02-2019, 03:22 PM
Default Is the 2007 TPMS active or inactive?
I've read that the 2007-2009 have active TPMS, but my MMI seems to be for an inactive system. I can't tell what I have. Below are pictures of my MMI and valve stem. I want to buy new wheels and tires, so I'm trying to figure out what I need.
ticklechicken is offline
Old 04-02-2019, 03:25 PM
raj99's Avatar
You are referring to direct or indirect tpms. Yours is direct system, whereby the sensors are located in the tires.
raj99 is offline
Old 04-02-2019, 03:31 PM
Thanks for the correction.
For my own education, can this be determined from my pictures? Or is this just something you knew the answer to?
Old 04-02-2019, 03:34 PM
uberwgn's Avatar
Most Audis went to the indirect (sensor-less) system in 2010 for the USA.
Rubber valve stem vs. metal valve stem is also a give away on Audi.
uberwgn is offline
Old 04-02-2019, 03:36 PM
raj99's Avatar
older gen q7 models were direct. You'll need the 433 mhz sensor
raj99 is offline
Old 04-02-2019, 05:50 PM
cuatrokoop's Avatar
Also note that not all 433 sensors are compatible. I bought a "generic" set that was supposed to work, but they would not. Had to get car-specific 433 sensors. That was expensive to fix.
cuatrokoop is offline
Old 04-02-2019, 06:18 PM
raj99's Avatar
Yes, steer clear from "universal" sensors...FWIW, I've had great luck with these: ITM 08003 433 MHz TPMS tire pressure sensors for Audi
raj99 is offline
Mickf29
RS4 (B7 Platform) Discussion
02-15-2009 04:22 AM
THE MEROVINGIAN
9
06-16-2005 11:19 AM
Mark P
Wheels & Tires Discussion
07-14-2004 05:28 AM
Mark P
01-22-2002 06:09 AM
Mark P
01-21-2002 12:27 PM
Quick Reply: Is the 2007 TPMS active or inactive?
