Go Back  AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 / Q8 > Audi Q7 > Q7 Discussion
Reload this Page >
2008 Audi Q7 4.2 Coolant Temp Sensor Fail
Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Sponsored By:
Sponsored By:
Old 05-26-2019, 12:54 AM
08' Audi Q7 4.2 FSI Owner
Willgatlin25's Avatar
Default 2008 Audi Q7 4.2 Coolant Temp Sensor Fail
I have no check engine light on right now but during an unrelated scan of the ECU Iím getting a coolant temp sensor failure code. Engine temp appears to rise and stay right about in the middle. Good strong heat comes into the cab. Only thing I notice is that the electric cooling fans seem to always come on after I park and shut the engine off. Not sure if this is normal operation but either way Iím still getting the temp sensor fail code.
Anyone know where the coolant temp sensor (s) are on the V8 4.2 Q7?
thanks.
Willgatlin25 is offline
Old 05-26-2019, 03:47 AM
The electric cooling fans will always come on after the car is parked up and being running for a while. They should only run for a couple of minutes though then shut off. What is the fault code associated with the temp sensor? The coolant temp sensor is located when looking at the front of the engine, to the middle but slightly to the right of the engine valley right at the front under the intake manifold, you will see a left, middle and right intake flap linkage group and its located just behind the righthand linkage. It may of been bumped etc when your mechanic took off your intake manifold 10 times but the good news is you can replace it without removing the intake again!!!
Up-it is offline
Old 05-26-2019, 04:25 PM
I can replace the sensor without removing the upper intake, even though itís under the intake? Do you have a picture of the sensor location or a diagram link by chance? Iíve been trying to google a diagram but havenít had any luck. Thanks!
Old 06-20-2019, 04:38 AM
I still havenít found this coolant temp sensor location. I had the upper intake manifold off 2 days ago and lookin around in there I didnít see anything that looked like a coolant temp sensor. I do see one coolant temp sensor right at the upper radiator hose but thatís the only one I found.
robsilvr85
Q7 Discussion
01-08-2015 11:48 AM
Jniebles
A4 (B7 Platform) Discussion
11-01-2012 06:28 AM
ufk22
03-03-2011 07:18 AM
red90q
01-11-2005 03:07 PM
absentme
10-10-2002 07:05 PM
Quick Reply: 2008 Audi Q7 4.2 Coolant Temp Sensor Fail
