2008 Q7 MMI doesn't work
The MMI system for my car stopped working, It boots up and then goes back to a black screen, I tried scanning it with vagcom and a lot of modules cannot be reached like Media Player, and radio, Here is the auto-scan
Code:
Sunday,13,January,2019,21:47:08:43805 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64 VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4 Data version: 20180927 DS296.0 www.Ross-Tech.com VIN: WA1BY74L88D046186 License Plate: Mileage: 154240km-95840mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4L (4L0) Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F 52 55 56 5F 61 62 65 69 6C 6D 6F 72 76 77 VIN: WA1BY74L88D046186 Mileage: 154240km-95840miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Cannot be reached 1100 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Cannot be reached 1100 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 5F-Information Electr. -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: Malfunction 0010 6F-Centr. Conv. II -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb Part No SW: 03H 906 032 CA HW: 03H 906 032 G Component: Q7 3.6-FSI-LEV2 G 1379 Revision: 5CH05--- Serial number: Coding: 0001175 Shop #: WSC 31414 790 00001 VCID: 63935263275F09CFE37-8036 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4L0 910 156 B HW: 0AT 927 156 Component: AG6 0AT 3,6 FSI USA 0010 Revision: --H04--- Serial number: 4036360 Coding: 0000002 Shop #: WSC 31414 790 00001 VCID: 2809054F1EF9AA97F65-807C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 B HW: 4L0 614 517 D Component: ESP ALLRAD MK25E1 0010 Revision: 00H30001 Coding: 0099345 Shop #: WSC 31414 790 00001 VCID: 290F004B05F3939FE9B-807C No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0230 Revision: 09010701 Serial number: 10601500967309 Coding: 0000131 Shop #: WSC 40124 444 999999 VCID: 63935263275F09CFE37-8036 Subsystem 1 - Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H46 0080 Subsystem 2 - Part No: 4F0 910 220 G Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4L0 910 043 B HW: 4L0 820 043 L Component: KLIMABETAETIGUNGH07 0030 Revision: 00---013 Serial number: 00000000149638 Coding: 0524326 Shop #: WSC 31414 790 00001 VCID: 2313126367DF49CFA37-8076 1 Fault Found: 00819 - High Pressure Sensor (G65) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 28 Mileage: 154217 km Time Indication: 0 Date: 2019.01.13 Time: 12:13:55 Freeze Frame: Temperature: 33.0°C Temperature: 2.0°C Load: 10.0 % Temperature: -55.0°C RPM: 1160 /min Absolute Pres.: 1.0 bar Current: 0.000 A Temperature: 7.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 K HW: 4F0 907 279 Component: ILM Fahrer H18 0250 Revision: 00000000 Serial number: 4F0907279 Coding: 0014123 Shop #: WSC 31414 790 00001 VCID: 313FE82B2D23EB5F21B-8064 Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H15 0100 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0100 Coding: 00150059 Shop #: WSC 31414 2 Faults Found: 02745 - Bulb for Daytime Running Light; Left 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 245 Mileage: 153996 km Time Indication: 0 Date: 2019.01.10 Time: 16:57:00 02746 - Bulb for Daytime Running Light; Right 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 245 Mileage: 153996 km Time Indication: 0 Date: 2019.01.10 Time: 16:57:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH42 0230 Revision: 06H42000 Serial number: 0038QD07BLKN Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B03FA430F0F818F1B7-807E Subsystem 1 - Part No: 4L0 910 339 A Component: BF-Gewichtsens. H03 0030 Subsystem 2 - Serial number: 6332QSME440723511 Subsystem 3 - Serial number: 6342QSME4401174DA Subsystem 4 - Serial number: 6352QSME4B180F11I Subsystem 5 - Serial number: 6362QSME441115699 Subsystem 6 - Serial number: 63734SME152D2077 Subsystem 7 - Serial number: 63834SME1521441DX No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 A HW: 4F0 953 549 D Component: J0527 0410 Revision: 00H03000 Serial number: 90025073480161 Coding: 0002042 Shop #: WSC 31414 790 00001 VCID: 270B067313E7A5EFFFF-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4L0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4L0 920 981 C Component: KOMBIINSTR. M73 H22 0240 Revision: 00000000 Serial number: 74234MF18 Coding: 3665288 Shop #: WSC 05300 758 69175 VCID: 2313126367DF49CFA37-8076 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1100B07C138227 Coding: F7D7FE77703A8200 Shop #: WSC 11111 123 12345 VCID: 2D07F45B311B8FBF053-8078 1 Fault Found: 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 231 Mileage: 153997 km Time Indication: 0 Date: 2019.01.10 Time: 16:54:03 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4L0 959 760 Component: Sitzmemory FS H01 0100 Revision: 00000000 Serial number: 00000000896401 Coding: 0082946 Shop #: WSC 31414 790 00001 VCID: 619F586B3D431BDFF1B-8034 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 793 B Component: TSG FA H12 0150 Revision: 00000000 Serial number: vd5 Coding: 0035531 Shop #: WSC 31414 790 00001 VCID: 2F3BEE533B17FDAF37F-807A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 F HW: 4L0 907 289 C Component: Komfortgeraet H07 0050 Revision: 0050 --- Serial number: 01087789250000 Coding: 7632925 Shop #: WSC 31414 790 00001 VCID: 3333E223D73FD94F537-8066 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 1 Fault Found: 03073 - Rear Lid Closed Sensor 1 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 32 Reset counter: 244 Mileage: 153886 km Time Indication: 0 Date: 2019.01.09 Time: 15:28:02 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H12 0100 Revision: Serial number: 00000000002654 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: 5EE563970C3D2427CC9-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 792 B Component: TSG BF H12 0150 Revision: 00000000 Serial number: yR5 Coding: 0035531 Shop #: WSC 31414 790 00001 VCID: 2F3BEE533B17FDAF37F-807A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 HW: 4L0 907 357 Component: AFS 1 H01 0030 Revision: 00000001 Serial number: Coding: 0000021 Shop #: WSC 31414 790 00001 VCID: 698F404BC573539F29B-803C Subsystem 1 - Part No: ----------- Component: AFS-Modul links Subsystem 2 - Part No: ----------- Component: AFS-Modul rechts 1 Fault Found: 02071 - Local Databus 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 231 Mileage: 153997 km Time Indication: 0 Date: 2019.01.10 Time: 16:54:48 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 5F: Information Electr. Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4L0 910 181 A HW: 4L0 915 181 Component: J0644 BEM H12 0690 Revision: -------- Serial number: 00000000046752 Shop #: WSC 08310 444 92086 VCID: 25170C7B69EBB7FFCD3-8070 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 2712191918 Coding: 344630393135313035442056413032373132313931393138 Shop #: WSC 31414 790 00001 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 4 Reset counter: 28 Mileage: 154154 km Time Indication: 0 Date: 2019.01.12 Time: 07:35:50 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 795 B Component: TSG HL H21 0150 Coding: 0035338 Shop #: WSC 31414 790 00001 VCID: 313FE82B2D23EB5F21B-8064 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl Part No SW: 4F0 910 273 B HW: 4F0 907 273 A Component: Reifendruck 3 H05 0100 Revision: 00050100 Serial number: 00000900063240 Coding: 0062424 Shop #: WSC 31414 790 00001 VCID: 221D176778C540C7A81-8076 1 Fault Found: 02214 - Tire Pressure Warning 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 50 Reset counter: 0 Mileage: 153997 km Time Indication: 0 Date: 2019.01.10 Time: 16:54:34 Freeze Frame: (no units): 0.0 Temperature: 4.0°C Error Code: 1 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 4E0-907-383.clb Part No SW: 4E0 907 383 E HW: 4E0 907 383 E Component: Anhaenger H14 0080 Revision: 2A002001 Serial number: 00000107390228 Coding: 0200000000000000 Shop #: WSC 31414 790 00001 VCID: 2C01F95F060186B712D-8078 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 4L0 910 441 A HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J7Z40WL Coding: 1021201 Shop #: WSC 31414 790 00001 VCID: 2411117F62D14EF7DAD-8070 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None Part No SW: 4L0 910 945 HW: 4L0 827 851 C Component: ValeoHeckdeckel H25 0290 Revision: --H25001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6C81395FCA8146B752D-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H25 0290 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD14.01.08--H25001001C0080ÿ Subsystem 4 - Serial number: 1C0080ÿ 3 Faults Found: 00317 - Rear Lid Control Module (J605) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 18 Mileage: 154056 km Time Indication: 0 Date: 2019.01.11 Time: 12:10:00 00532 - Supply Voltage B+ 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 15 Reset counter: 27 Mileage: 154010 km Time Indication: 0 Date: 2019.01.11 Time: 00:13:18 00447 - Function Limitation due to Over-Voltage 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 33 Reset counter: 29 Mileage: 154002 km Time Indication: 0 Date: 2019.01.11 Time: 00:08:01 ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H05 0060 Revision: AAH05061 Serial number: 003368856----- Coding: 0003595 Shop #: WSC 31414 790 00001 VCID: 26150B7714EDBCE7C49-8072 Subsystem 1 - Part No: 4L0 910 591 Component: J_245_EE16_SKB09H10 0200 Subsystem 2 - Part No: 4L0 910 591 Component: J_394_EE16_SKB09H10 0200 Subsystem 3 - Part No: 4L0 910 591 Component: J_392_EE16_SKB09H10 0200 1 Fault Found: 02960 - Lamp in Bumper; Rear Left 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 28 Mileage: 154078 km Time Indication: 0 Date: 2019.01.11 Time: 14:23:28 Freeze Frame: Bin. Bits: 100 000 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 794 B Component: TSG HR H21 0150 Coding: 0035338 Shop #: WSC 31414 790 00001 VCID: 313FE82B2D23EB5F21B-8064 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 H HW: 4F0 919 283 H Component: Parkhilfe 8-Kan H12 0080 Revision: 00H12000 Serial number: 06340736100313 Coding: 0231246 Shop #: WSC 31414 790 00001 VCID: 290F004B05F3939FE9B-807C No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End----------(Elapsed Time: 02:11, VBatt start/end: 14.8V/14.8V)-----------
lonecrow
VAG-COM Discussion
04-18-2006 07:13 PM
Mr. Z
03-17-2006 08:25 AM
OneEyedJack
02-03-2006 07:06 AM
SLVR6
NY / NJ / CT Discussion
10-18-2005 07:42 AM
dgrays4
12-08-2004 06:02 AM
