2011 q7 led daytime lights
Does anyone know if the small led lights that run around the headlight are replaceable? I can not find the part number on the headlight diagram. I have 2 that are not working.
You could take the headlight apart and solder in 2 new ones, but good luck with finding the right ones. Best bet would be picking up a new or used unit, and then just reusing all your bulbs and ballast.
Give this guy a call and see if he still has the broken unit.
https://www.audiworld.com/forums/par...030al-2934606/
Then you could shore up the two into one unit.
