2013 q7 3.0t oil filter o ring location
Hi. I just did a oil change myself. I'm not sure if I put the o ring at the right place on the housing. I found a light oil leak if I put my finger at the bottom of housing. I put 18 ft lbs to tight it up. I have searched for a photo of the o ring location but no luck. Can you guy provide a photo if you can. Thanks a lot
That one is in the right place, but I was wondering if there should be another one at the bottom, under the threads. I'm leaking oil, and I suspect I'm missing one of the seals. Just started to remove the filter housing, but now I wonder, if I need to.
Mike141
21
01-04-2011 04:24 AM
BridgeRC
11-30-2005 09:58 AM
