2013 Q7 Running Boards
Tow hitch hardware occupies some of the mounting holes also running boards use. Some reported already that they have successfully installed sharing the same mounting points. Use the "search" function, you'll be surprised to see how many topics already out there.
aftermarcket running boards
u can use aftermarket running boards from romik:
http://www.romik.com/products/
Finally the Romik running boards arrived. I installed them with-in an hour. Quite easy to install actually. Following the instruction, I pull off four rubber covers and two plastic covers. Using the provided bolts to install. The trick is Romik provides eight special bolts to fit in the holes. Attache some pictures before and after.
