Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Sponsored By:
Sponsored By:
2014 Q7 TDI Fumoto Drain Valve
Old 04-10-2019, 06:05 PM
Default 2014 Q7 TDI Fumoto Drain Valve
Has anyone used a Fumoto drain valve on the Q7 TDI engine? There is a cross brace under the engine close to the drain plug so Iím not sure it will work. I have a 15 gallon vacuum oil extractor but prefer to drain from underneath so I can inspect other items at the same time. I have a valve on my truck with a Cummins diesel for the past 365k miles and love it. No mess and no leaks. I may just try one and see if it fits.
Dudeness30 is offline
Old 04-10-2019, 09:11 PM
cuatrokoop's Avatar
You need the F106SX, I just went through the same thing on my '13 (the SX uses a Banjo bolt, which is the key to it fitting). Might want to get a hose, as it will shoot the oil straight back when you open the valve. It comes with the new valve lock also.
cuatrokoop is offline
Old 04-11-2019, 03:34 AM
Good info thanks, itís on order.
mechno1
09-19-2011 10:06 AM
juttin
03-21-2011 06:43 AM
92-100S
12v V6 Discussion
12-27-2004 04:22 PM
Zed 2.0
10-06-2002 05:55 PM
Jack in FL
Misc. Models Discussion
01-07-2001 07:50 PM
Quick Reply: 2014 Q7 TDI Fumoto Drain Valve
