2014 Towing advice
I am planning on using my 2014 Q7 with the factory supplied hitch rated at 6,625 In per label on hitch and in the owner's manua to tie a 2900 In car on a U Haul 2200 Ib trailer.
The total drive time is about 12 hours, but will be only doing 6 hours a day. Questions: . Should I have any concerns towing aprox 5100 pounds? . I had a recent checkup that included all fluids, and the brakes have less than 4000 miles on them. What else should I worry about? . Any other pointers or advice? Many thanks in advance Sam 2014 Q7 Premium Plus |
Is it a TDI? When we drive cross country with a 5x8 U-Haul we burned a bunch of AdBlue and had to refill at 5700 miles since last oil change vs 10k miles normally.
Make sure you have the electrical connector installed in the back already. It should look like this: http://www.etrailer.com/Custom-Fit-V...leid=201563765 If you've got a gasser I'd say you'll be just fine at that weight and limited cd of an auto trailer. Grey |
It is a gasser...
Thanks Gary. |
Make sure you have an electrical connector on the back next to the hitch. It looks like this:
http://www.etrailer.com/Custom-Fit-V...leid=201563765 Grey |
yep, I just looked it up today... will pick one up.
My other concern is that I will be driving across Pennsylvania with some steep climbs. I wonder if the ~290 pounds of torque will do the trick? |
Originally Posted by Dr Zorba
(Post 25194613)
The total drive time is about 12 hours, but will be only doing 6 hours a day. Questions: . Should I have any concerns towing aprox 5100 pounds? . I had a recent checkup that included all fluids, and the brakes have less than 4000 miles on them. What else should I worry about? . Any other pointers or advice? Many thanks in advance Sam 2014 Q7 Premium Plus dont fret it! |
5100# requires trailer brakes, you'll need to install a brake controller and make your own harness to hook it up.. since its a uHaul I would suggest at least testing it with a multimeter before going to pickup the trailer.
Originally Posted by dreadlocks
(Post 25194711)
Originally Posted by jbgilbank
(Post 25194691)
no worries at all! I towed 10,000 lb. 7x14 enclosed across the US with my 2015 gas! Super impressed! dont fret it! But that said, I'd have no issue with pulling 5100lbs across the country with any 4.2 or 3.0 Q7, all three have Aisin transmissions and would be rated to either 6600 or 5500 lbs depending if it has factory tow or not. I'd run the 3.6 if it had factory tow to pick up the extra cooling capacity or if it had an aftermarket trans cooler to keep the ZF running cooler when things got hilly. |
(Post 25194613)
