2015 Audi Q7 3.0T Oil Drain Plug Location
#23
#24
I know it suck having the crossmember blocking the drain plug. On mine, I used a wide open oil pan, which I bought for 3 bucks. I did loose the drain plug little by little to prevent a high oil splash and spill. In the end it was a clean oil change except for the crossmember.
#25
Mr. Patterson, I have drained the oil. I am ready to change the oil filter. I just need to double check with you whether I am looking at the correct oil filter housing in red and crankcase cap in yellow in the picture attached. Does the oil filter housing open clockwise? Thank you.
#26
Hi. Everyone. Im looking for help on the oring. I have the same vehicle. But found a minor oil drip below the housing after driving. I have photo attached. Hope someone can tell me if the oring at the correct position.
SeattleA4
10-28-2001 08:34 PM
