2015 Q7 VCDS Gear Indicator Success
#11
As you can see why I would be horrified!
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE6FD008394 Mileage: 61250km-38058miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (CTW) Labels: None
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 3635DBE4644C6517984-8062
#12
I didn't get any of that experimental warnings and would be terrified to "Do It!" also if I did get those. While you reported your coding was the same as mine (Toureg is a normal coding for these as it used the same tranny though I believe I read they had a more aggressive gearing program which is preferred.)
If I were you I'd reach out on the Ross-Tech forum since you are a legit owner and they should be able to figure out why you are seeing that...
#13
VIN: WA1DGAFE6FD008394 Mileage: 61370km-38133miles
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
#14
Hey mate, firstly I noticed with your scan it shows chassis type “4F” im pretty sure this is like an A6 or something, like i said earlier it needs to be picking up 4L for earlier Q7’s and new generations are 4M.
also when it displays “malfunction” next to the particular modules for you its 01, 05, 34 & 6D its just indicating you have a logged or active fault with that system it controls.
you will need to individually select these control modules, read the code and determine the fault & maybe clear it if its an oldy.
all the coding numbers you shoukd take a screen **** with your phone before playing with it. As if you change some numbers for the worse you can always revert back wnd punch in the original code bud.
dont be scared to use VCDS just be careful with what you do with it.
#15
I did not change anything that would have changed that. I am very specific and careful with changes and I do copy and paste coding into an ongoing notepad for future reference or if something gets Fd up.
I also keep a word doc with screenshots for many things.
In fact, this (below) was my very first scan before I touched or changed anything, even the green screen, which was the very first mod I made. I just realized there were codes thrown here. I don't remember if that was because I forgot to turn the key on, or if that was a couple runs in that I did that.
I did go through and cleared all codes individually in each module this morning. I will give it a couple of days and check them again.
I did manage to get the rear markers disabled.
VIN: WA1DGAFE6FD008394 Mileage: 60670km-37698miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
#16
By the way, Gear Indicator + Paddle Shifters = Win for towing trailers on grades. It really helps me to pre-shift when anticipating grade changes so the transmission doesn't hunt or work as hard.
#17
It might go without saying (should have been said to me...), some functions cannot be changed when the engine is running. I tried this Gear Indicator change many times and it wouldn't take on my 2014. Then I used the key in the ignition partially turned and it took right away. Based on your ABS disaster you might have something else going on.
I always (after learning the hard way like yourself) use the key when entering VCDS.
This particular issue is my interaction with module through VCDS:
- Current Gear Supression Disabled
02 Auto Trans - Coding 7 = 001378 Long Coding Helper
POPUP = (both verified and experimental coding information are available for this module. Do you want to use experimental coding information?)Yes
POPUP = (VCDS is about to send experimental coding information to Lcode. This information is unverified, untested and you will be using it AT YOUR OWN RISK. Do you want to proceed? Press yes for experimental information or no for confirmed coding information.)Yes Byte 0-2 (1378 Country Coding, Toureg - NAR)
Question is, What do I do?How do I make the change after all that?
Did you experience any of this during your process? If not, why would mine?
Thanks for all the help!
#18
All correct until "Do you want to use experimental coding?" (I select "No")
When the long coding helper opens, press down arrow on your keyboard twice. The option to suppress gear indication should appear as the second checkbox on a list. (Pressing the down arrow on this screen just moves from Byte to Byte. You want to change bit 1 of byte 1.
Unselect the box, exit the long coding helper, save.
Nowhere in the process did I have to select which vehicle I have.
#19
I just ran out and checked.
#20
POPUP = (both verified and experimental coding information are available for this module. Do you want to use experimental coding information?)No
Change bit 1 of byte 1.
Looks Right!
