Adaptive air suspension - AudiWorld Forums
Go Back  AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Audi Q7 > Q7 Discussion
Reload this Page > Adaptive air suspension
Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Old 01-09-2018, 09:57 PM
Default Adaptive air suspension
Hi,
I purchased a used 2007 Q7 3.6 Premium. It does not have the Adaptive Air Suspension. Was it optional or standard?
SamPer is offline
Old 01-10-2018, 08:58 AM
xThinG's Avatar
Originally Posted by SamPer View Post
Hi,
Hello,Did you checked via the MMI and you hadn't the ability to bypass? Or nothing appears in console?Because it could be removed by the owner due to a failure or something
xThinG is offline
Old 01-10-2018, 09:52 AM
Hi, Thanks for the reply.
Nothing appears on the console. I dont see any options on the console
SamPer is offline
Old 01-10-2018, 10:51 AM
Hi,
Your unit either has it or it does not. You can look and see if your struts are air bags or coil overs (correct me if I'm wrong).
If they are air bags, you can go to MMI (car) and you will see adjustments.
jbgilbank is offline
Old 01-10-2018, 10:55 AM
Thanks, but how do i check if the struts are airbags or coil overs? I'm not a technical guy, so any advice would be appreciated.
SamPer is offline
Old 01-10-2018, 05:00 PM
Force-1's Avatar
Look underneath. If you see this you have air suspension.
Like this? Non-air.
Force-1 is offline
Old 01-10-2018, 05:35 PM
plat27265's Avatar
Hi,
Optional. Here's the official Audi press release for the 2007 Q7: https://www.audiworld.com/model/q7/07/2007%20Q7.pdf
plat27265 is offline
Old 01-10-2018, 06:18 PM
raj99's Avatar
I really like the AAS in my 09 Q7 and here's a great doc which describes in detail how the system is setup and all the components involved
File Type: pdf
raj99 is offline
Old 01-10-2018, 07:15 PM
Thanks Mate
SamPer is offline
Old 01-10-2018, 07:16 PM
Thanks a ton for this image. Will have a look at it
Best,
Sam
SamPer is offline
rmur23
A4 (B9 Platform) Discussion
03-28-2017 01:45 PM
Pmpsch
Q7 MKII Discussion
14
12-06-2015 02:14 PM
AudiStory
Q7 Discussion
05-19-2007 03:59 PM
ChooChooNongNongHead
Off-topic Discussion
06-28-2006 05:32 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
