Air Con coming out hard at back but not front vents?
Hi,
I just recently purchased 2008 Q7 4.2 litre Diesel. Love it, however when I was driving home the air con started going on it. I went online and saying blower motor so ordered one and replaced myself.
The fan makes a lot of noise so seems to be working ok. I took out the cabin filter (which was filthy) and blows a little better but not strong enough to keep cool on hot days here in Australia.
The back seems to blow pretty hard but the front vents feel like they are on 3-4 blower speed however I have them at 12!
If anyone can help it would be greatly appreciated.
Thank you, Beau
Thank you, Beau
Hi,
Thank you, Beau
Thank you, Beau
but back to the front fan issue. Have you tried changing the vent air delivery positions? not just on auto? ie. like foot area or r/h side only etc to determine the fault is with all vent locations. These also need to be selected under the mmi screen also mate.
let us know how you go.
thanks Doug
Do you have a Ross-Tech Vagcom? If you, do under the Auto HVAC setting you can run a flap servo learning procedure to relearn the new positions. There are also other options that you could run to help narrow down what the problem is.
THANK YOU
Thank you for your replies.
I have tried everything with the MMI without any success. And thanks for letting me know why the back is working fine Doug, makes sense they are run independent as I could not work out why the back was getting 12 speed blower and the front couldn't.
I have purchased a new blower motor online however the casing was for a left hand vehicle, even after informing them of where I was and my model etc said it would fit.
Anyway I took the old casing off and replaced the motor without success. I have now ordered a A/C HEATER BLOWER FAN RESISTOR SPEED CONTROLLER from ebay and hopefully that will do the trick. (Just waiting for that to arrive)
Does anyone know if that fan motor would spin in the wrong direction being meant for a left hand drive or would it be the same?
Thanks again for all your help, I will let you know how I go.
Thank you,
Beau
Thank you,
Beau
fusilier
08-26-2006 02:17 PM
sohcrates
11-19-2002 09:00 AM
Sacto Ming 2.7T
09-26-2000 06:07 PM
