Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Anyone with 07-09 Q7 and VCDS; Questions On Modifications
Old 01-24-2016, 10:59 AM
D3Audi's Avatar
Default Anyone with 07-09 Q7 and VCDS; Questions On Modifications
Thinking on purchasing a VCDS, if there is anyone with a 2007-2009 pre facelift Q7, could you see if there is an option to turn off cold diagnostics? Cold diagnostics sends quick pulses to each bulb, but when having LED bulbs, it causes the LEDs to strobe. That's the most important thing I need to change, I'm curious if it's possible.
Old 01-24-2016, 04:05 PM
sethroid's Avatar
I just looked a little while ago and couldn't find it.
Old 01-24-2016, 04:07 PM
D3Audi's Avatar
Thanks for that info, I don't even know where it would be in the VCDS programming. I really hope there is a way.
Old 01-28-2016, 05:14 PM
D3Audi's Avatar
Just spoke with someone who is very knowledgeable on VAG coding. He said to check under "central electronics module coding" it would be listed as "cold diagnostics" or "LED" depending on the vehicle. Debating on purchasing a VCDS to disable cold diagnostics., is there anyone who can confirm that this indeed works?
Old 01-29-2016, 05:09 AM
sethroid's Avatar
Here is Central Electronics. As you can see there is no long coding helper. But the little help popup shows all the options.
Old 03-21-2024, 02:50 AM
Darius0548's Avatar
I tried to put United States of America from VCDS like in upper photo on the last number from coding, I put 3 and I didn’t notice again after that to flicker🤷🏻‍♂️, only when I put ignition on, but after not. Sorry for bad English
Old 03-21-2024, 02:52 AM
Darius0548's Avatar
And on the lights type, if I remember good, I put led day time running lights with or w/o washer.
chuckee98
02-14-2013 10:09 PM
pspitzer
Audi A3 / S3 / RS 3
04-29-2009 07:55 AM
raduga
Audi A3 / S3 / RS 3
11-16-2005 06:00 PM
CalG
VAG-COM Discussion
06-09-2004 07:22 AM
xMIKEx
Audi 100 / A6 (C4 Platform)
15
11-11-2002 07:36 AM
Quick Reply: Anyone with 07-09 Q7 and VCDS; Questions On Modifications
