bad gas smell
bad gas smell
My friend has an audi q7. 2010 model. When he started the engine, we can smell a bad gas smell inside the cabin. We thought that the gas come out from the air cond. It happens regularly. Then he takes his car to an audi repair shop and got his aircond filter changed. But the gas can still be smell. It is fine at first but become worse day by days. I want to ask . Does this problem related to engine? And is it carbon monoxide gas? Coz the gas makes my nose feel pains a bit.
AudiWorld Expert
my only guess would be the recall that is out right now for fuel leak but 2010 didn't fall under that according to VAG perhaps it is a late build 2010 and it is affected?
http://www-odi.nhtsa.dot.gov/acms/cs...5V019-4663.PDF
Nurul Alida, where are you located? Outside of USA? If you are outside of USA then that 2010 model would be the same as a USA spec 2011 model.. Its because the rest of the world gets the newer model 1 year ahead of USA. And if that's the case then I believe it is the same problem as Iconoclast brought up which has a USA open recall for it. The fuel leak.
EBG 18T [Eric]
Rocky Mountain Discussion
05-01-2007 09:18 PM
illphil4
03-13-2007 04:48 PM
S4MADNESS
9
06-12-2001 09:35 AM
