Best Replacement Brake Pads for 2015 Q7?
#31
take one of the old sensors, cut it off, short it together and use it on each side at a time til you find which one is giving him a problem.. then inspect and replace if needed, might not be plugged in all the way, need contacts cleaned, broken.. who knows, but the fault does not need cleared, it will go away when all sensors are operable.
#33
I also suggest you take an old one and make a tester by shorting it and trying it in each position. You can also check continuity in each of the new sensors with a VOM. I would suspect that the problem lies with the connector rather than the sensor itself however.
#35
#36
I am ready for my second set of brakes (44,000 miles). The last time it was a $2k brake job at the dealer and this time I would like to try something else with less brake dust but at the same time not lose too much braking power. I checked out some of the old threads:
https://www.audiworld.com/forums/q7-...2905384/page2/
https://www.audiworld.com/forums/q7-...2897344/page5/
I am trying figure out what is the best ceramic pad?
#37
Just an update for everyone - I bought the $500 front back kit from Amazon w/ ceramic and drilled/cross slotted rotors. Put them on fairly easily (except you need the torx socket bits).
Put about 4,000 miles on them and no issues at all. No noise, VERY little dust on my bright silver 22" split spokes compared to what was on there before (likely dealer pads from prev owner).
Only thing special I did was mask and spray the inner portion of the rotors with silver ceramic high temp paint - very carefully to avoid getting paint on the braking surface. Looks great and should prevent them from rusting or corroding like many rotors do.
I'll report back after I get more miles on them.
#38
