Collapsible spare for Q7 won't inflate
#11
You need to buy valve core removal tool. You can find at any auto parts store.
http://www.autozone.com/autozone/acc...er=487510_0_0_
Remove or release valve core a little and the pressure will inflate the spare tire no problem. When you get it inflated, turn the valve core back in place.
With the valve core tightened in there. The air pump cannot inflate the spare tire. Once I removed the core, spare tire is inflated fast!
#13
#14
You need to buy valve core removal tool. You can find at any auto parts store. http://www.autozone.com/autozone/acc...er=487510_0_0_ Remove or release valve core a little and the pressure will inflate the spare tire no problem. When you get it inflated, turn the valve core back in place. With the valve core tightened in there. The air pump cannot inflate the spare tire. Once I removed the core, spare tire is inflated fast!
#15
Managed to solve it with my Q5 2013
anaged to solve ot after several trials
I have an Audi Q5 2013,
I managed to overcome the collapsible tyre problem,
The problem when u try to inflate the tyre with car compressor is that sometimes the tyre is not properly fitted in its rim so the air is leaked out and the tyre will never inflate, with the strong compressor at service center you won’t find a problem to inflate it, as the strong air pressure will overcome the leakage.
so the solution is to keep some air inside the tyre when you deflate it to make sure it is fitted with the Rim, then when you try to inflate using the provided car compressor it will inflate properly with no problems,
attached images showing:
-The level of air you have to keep inside the tyre.
- The tyre can fit in its place even if not completely deflated.
The following 3 users liked this post by Hossam Abdelwahab:
#16
Useless engineering
The Audi supplied compressor generates heat but no air pressure. Maybe it would be a good heater in the winter. I even tried a separate heavier compressor and the tire did not budge. Garbage system.
#17
I have used mine once to inflate the spare. This over 10 years with 2 Q7s. The little compressor worked OK. Took a long time but that’s to be expected. Have used it quite a few times for bicycle tires. Works there too
:-). I keep a plugging kit in each of our Audi‘s. It’s usually faster to plug a tire than it is to change it out for the spare.
#18
You'll almost surely kill yourself attempting to get the flat or damaged tire & wheel off this car unless you have a lengthy breaker bar and managed to stop on a solid, nearly level surface. We replaced worn runflat tires on the '15 partly for this very reason, and are quite happy with them.
TPMS is really your best defense on this car, as that has saved my bacon a couple times now when I picked up a nail or screw in a tire by alerting me to the pressure loss before it became a major tire or rim mangling event.
#19
Hi,
I tried inflating the collapsible spare for the Q7. The owner's manual is silent on this. I used two different compressors and none would inflate it, the air just pumps and comes out of somewhere. It' been inflated before by a shop, and I know it's not flat since it's never been driven on. There is this tricky part with the valve and the screw, I tried screwing the tip all the way in, all the way out, and mid-way, and tried inflating in all 3 positions, and it still will do nothing. Such a simple task seems complex, what's the trick to this?
