Door sensors stopped working?
Took our 2015 Q7 in to get clear bra and ceramic coating installed on it by a very reputable shop here. When we picked it up yesterday the door sensors no longer are working (neither unlocking to the touch, or locking by pushing the button), neither is the start button in the center console. Car starts fine with the key in the ignition and there doesn't seem to be any drivability issues. They did say that they had to put a charger on it because with them having the doors open so much they drained the battery. I know that these cars can get testy when the battery is drained so am wondering if that is causing all the issues. I ran an auto-scan (see below) and there are all kinds of faults for under voltage. So what should my next step be? Just clear them all an hope for the best? Or should I take it in and have the dealer deal with it. Like I said, the shop that did the work is standing behind fixing the issue, and even said they would probably just take it to the dealer, but if it is an easy fix and I don't need to be out of the car for a couple days I would prefer to fix it myself. What is your guys' advice?
Sunday,10,March,2019,11:22:55:57302
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WA1DGAFE9FD030048 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
4F 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE9FD030048 Mileage: 65830km-40904miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0A28
Shop #: WSC 31414 790 00001
VCID: 363524ACA44A80D7741-8062
1 Fault Found:
001110 - EVAP System
P0456 - 000 - Very Small Leak Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 65003 km
Time Indication: 0
Date: 2019.02.11
Time: 06:56:10
Freeze Frame:
Lambda: -2.0 %
Temperature: 22.5°C
Time: 3.50 s
Time: 4.60 s
Time: 128.0 s
Temperature: 13.5°C
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number:
Coding: 001378
Shop #: WSC 63270 001 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 3A2D309C9CD264B7909-806E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627793
VCID: 34311EA4B23692C74A5-8060
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:28
Freeze Frame:
Count: 128
Count: 11073
Count: 128
Count: 25856
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 65775 km
Time Indication: 0
Freeze Frame:
Count: 192
Count: 11073
Count: 297
Count: 25600
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902212691
Coding: 0000135
Shop #: WSC 03824 003 1048576
VCID: 2517F3E009ECFB4FCDB-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 65775 km
Time Indication: 0
Date: 2019.02.28
Time: 17:24:04
01176 - Key
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 11:42:52
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:13
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 16:50:58
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000030389474
Coding: 000CC026
VCID: 2517F3E005ECFB4FCDB-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0147795236
Coding: 070000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:35
Freeze Frame:
Voltage: 7.20 V
01592 - Air Quality Sensor (G238)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:19
Freeze Frame:
Temperature: 19.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133123
VCID: 6E85CCCC9C9AF8177C1-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.05
Time: 09:34:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.05
Time: 09:34:00
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931514704991
Coding: 290120
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311EA4BEB692C74A5-8060
3 Faults Found:
1112369 - Front Right Center Parking Aid Sensor
B10F9 31 [008] - No Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 127
Mileage: 65321 km
Date: 2019.02.14
Time: 21:00:30
1112324 - Front Right Center Parking Aid Sensor
B10F9 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 65282 km
Date: 2019.02.14
Time: 15:50:54
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0011111
VCID: 270BF9E873E0E95FFF7-8072
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:14
Freeze Frame:
Temperature: 20.0°C
Voltage: 11.78 V
Bin. Bits: 01000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH46 0230
Revision: 10H46000 Serial number: 0038QDA025P6
Coding: 0014131
VCID: 2B0305D86F08CD3F1BF-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME5453034A9
Subsystem 3 - Serial number: 6342QSME5A530366E
Subsystem 4 - Serial number: 6352QSME6A561260D
Subsystem 5 - Serial number: 6362QSME5453305EH
Subsystem 6 - Serial number: 63734SME715929641
Subsystem 7 - Serial number: 63834SME234B3342Y
1 Fault Found:
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026151330286
Coding: 0012152
VCID: 2809FAD47EFEE627F6D-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:07:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:08:17
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 F HW: 4L0 920 985 F
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2C00LT5G
Coding: 8BD663040D01CF05020205
VCID: 372B29A8AF4079DF6F7-8062
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M155110B9A
Coding: 00C303
VCID: 3FDB41888770419FA77-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32140445094121971314
2 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 13:41:08
Freeze Frame:
Bin. Bits: 00000
Voltage: 11.10 V
Count: 8
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:33
Freeze Frame:
Bin. Bits: 00000
Voltage: 8.30 V
Count: 8
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---012 Serial number: 00000000478118
Coding: 0000006
VCID: 6889BAD4BE7E262736D-803C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:34
Freeze Frame:
Voltage: 7.20 V
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:29
Freeze Frame:
ON
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 63964 001 1048576
VCID: 313F17B04D24A7EF213-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 144
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Error Code: 13
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 146
Mileage: 65779 km
Time Indication: 0
Date: 2019.03.09
Time: 09:42:52
Freeze Frame:
Error Code: 68
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000149105295
Coding: 00581B00000011110000
VCID: 323D18BC44229CF7589-8066
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 0 km
Time Indication: 0
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 E HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0030
Revision: 00H03000 Serial number: 6PZ 009 014-16
Coding: 0010001
VCID: 303912B4462EAEE72ED-8064
Subsystem 1 - Part No: 4L0 910 568 E
Component: J0770_SWA_Slave_H03 0030
Subsystem 2 - Serial number: 6PZ 009 014-36
Subsystem 3 - Serial number: 5F18.05.1500H03000AMS14006ÿ
Subsystem 4 - Serial number: S14006ÿ
2 Faults Found:
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:29
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:30
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000152669571
Coding: 011F57205E40440004
VCID: 48C95A54D2BE062716D-801C
3 Faults Found:
01705 - Selection Switch for Mirror-Adjust (E48)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 16
Reset counter: 144
Mileage: 65127 km
Time Indication: 0
Date: 2019.02.12
Time: 20:42:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Time Indication: 0
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82010220430000
Coding: 3569949
VCID: 38292A94AE5E76A766D-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:15:37
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000088375
Coding: 030000
VCID: 290FFFD069F4DF2FE93-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191104139
Coding: 0694221
VCID: 2313EDF807D8057FA3F-8076
3 Faults Found:
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 142
Mileage: 65366 km
Time Indication: 0
Date: 2019.02.15
Time: 17:55:51
Freeze Frame:
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 15.0°C
(no units): 106.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 9.00 V
Temperature: 18.0°C
(no units): 255.0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 9.00 V
Temperature: 18.0°C
(no units): 255.0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H17 0100
Revision: Serial number: 00000000239483
Coding: 0012001
VCID: 5EE59C0C6C3A6897CC1-800A
3 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.04
Time: 09:05:00
Freeze Frame:
Voltage: 7.400 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.04
Time: 09:31:00
Freeze Frame:
Voltage: 7.400 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:00
Freeze Frame:
Voltage: 8.400 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000152676107
VCID: 47CB5968DFA0095F1F7-8012
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.05
Time: 09:32:46
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.05
Time: 13:44:03
02124 - Exterior Door Handle Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 07:19:32
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:27
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F/0F8271670
Coding: 020007010000000000
VCID: 2411EEE40ED60247DA5-8070
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:41
Freeze Frame:
Voltage: 8.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 16:51:18
Freeze Frame:
Voltage: 8.90 V
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513FY0F7525045
Coding: 180200060004F9EF710023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130FU0F3367064
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002253923
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:39
Freeze Frame:
Voltage: 8.40 V
03367 - Supply Voltage for Display Module
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:03
Freeze Frame:
Voltage: 6.80 V
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000152697173
Coding: 010E57204040230004
VCID: 46D5546CD8AA1057E41-8012
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 07:43:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:57
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000370513652
Coding: 0200000000000000
VCID: 313F17B04124A7EF213-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:49
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0231842
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E85CCCC901AF8177C1-803A
2 Faults Found:
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Functional limitation by undervoltage]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 144
Voltage terminal 30: 6.7 V
Terminal 15 status: Terminal 15 on
9617993 - Proximity Camera
B145C 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 107
Mileage: 64900 km
Date: 2019.02.08
Time: 15:39:09
Voltage terminal 30: 13.4 V
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H61 0500
Revision: --H61001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C6C4AA860A07525-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: ó
Subsystem 3 - Serial number: RD28.05.15--H61001002F0234ÿ
Subsystem 4 - Serial number: 2F0234ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0152929329----
Coding: 0003595
VCID: 2615F4EC74EAF057C41-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
4 Faults Found:
01512 - Control Module for Sliding Roof
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:08:23
02906 - Control Module for Sliding Roof; Rear (J392)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:08:23
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:17:47
02907 - Control Module for Roof Shade (J394)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 10:31:38
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000152697117
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 07:43:45
End----------(Elapsed Time: 02:31, VBatt start/end: 12.3V/12.3V)-----------
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 65003 km
Time Indication: 0
Date: 2019.02.11
Time: 06:56:10
Freeze Frame:
Lambda: -2.0 %
Temperature: 22.5°C
Time: 3.50 s
Time: 4.60 s
Time: 128.0 s
Temperature: 13.5°C
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0627793
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:28
Freeze Frame:
Count: 128
Count: 11073
Count: 128
Count: 25856
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 65775 km
Time Indication: 0
Freeze Frame:
Count: 192
Count: 11073
Count: 297
Count: 25600
Coding: 0000135
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 65775 km
Time Indication: 0
Date: 2019.02.28
Time: 17:24:04
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 11:42:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 16:50:58
Coding: 000CC026
Coding: 070000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:35
Freeze Frame:
Voltage: 7.20 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:19
Freeze Frame:
Temperature: 19.0°C
Coding: 0133123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.05
Time: 09:34:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.05
Time: 09:34:00
Coding: 290120
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 127
Mileage: 65321 km
Date: 2019.02.14
Time: 21:00:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 65282 km
Date: 2019.02.14
Time: 15:50:54
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 0011111
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:14
Freeze Frame:
Temperature: 20.0°C
Voltage: 11.78 V
Bin. Bits: 01000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: 0.0 km/h
Coding: 0014131
1 Fault Found:
Coding: 0012152
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:07:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:08:17
Coding: 00C303
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 13:41:08
Freeze Frame:
Bin. Bits: 00000
Voltage: 11.10 V
Count: 8
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:33
Freeze Frame:
Bin. Bits: 00000
Voltage: 8.30 V
Count: 8
Coding: 0000006
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:34
Freeze Frame:
Voltage: 7.20 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:29
Freeze Frame:
ON
Coding: 0015520
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 144
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Error Code: 13
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 146
Mileage: 65779 km
Time Indication: 0
Date: 2019.03.09
Time: 09:42:52
Freeze Frame:
Error Code: 68
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 0 km
Time Indication: 0
Coding: 0010001
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:29
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:30
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 144
Mileage: 65127 km
Time Indication: 0
Date: 2019.02.12
Time: 20:42:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Time Indication: 0
Coding: 3569949
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:15:37
Coding: 030000
Coding: 0694221
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 142
Mileage: 65366 km
Time Indication: 0
Date: 2019.02.15
Time: 17:55:51
Freeze Frame:
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 15.0°C
(no units): 106.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 9.00 V
Temperature: 18.0°C
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:13
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 9.00 V
Temperature: 18.0°C
(no units): 255.0
Coding: 0012001
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.04
Time: 09:05:00
Freeze Frame:
Voltage: 7.400 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.04
Time: 09:31:00
Freeze Frame:
Voltage: 7.400 V
Temperature: 77.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65772 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:00
Freeze Frame:
Voltage: 8.400 V
Temperature: 77.0°C
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.05
Time: 09:32:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.05
Time: 13:44:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 07:19:32
Coding: 0000032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:11:27
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:41
Freeze Frame:
Voltage: 8.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 16:51:18
Freeze Frame:
Voltage: 8.90 V
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:39
Freeze Frame:
Voltage: 8.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 08:12:03
Freeze Frame:
Voltage: 6.80 V
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 07:43:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:57
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:02:49
2 Faults Found:
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 144
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 107
Mileage: 64900 km
Date: 2019.02.08
Time: 15:39:09
Coding: 0003595
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:08:23
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:08:23
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 08:17:47
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.04
Time: 10:31:38
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.01
Time: 17:01:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 144
Mileage: 65775 km
Time Indication: 0
Date: 2019.03.07
Time: 07:43:45
Leaving the doors open wont kill the battery, it'll shut down before it lets that happen.. but the handles shorting out will..
Clear codes and see if that helps, you might also need a new battery.. 4 years is about average if you live in a climate with real winters.. If they still fault after clearing codes then you'll need to replace the handles or at least disconnect em so they wont continue to drain battery.
I guess my bigger question is, would the stored faults cause these things to continue to not working? If they are intermittent faults, why wouldn't the functions work now that the voltage is back to a satisfactory level (battery is now at 12.4V) even with the stored faults.
if you clear codes and they come back then they are persistent and faulty, you saved the scan and the milage and everything so its not like you got anything to loose.. many things go into a 'safe' mode until codes are cleared,
Could be the key fob battery too. Mine caused similar symptoms when it was dying (door handle button unlocking and push-to-start both dead). 4 years is about right for the key fob battery to die.
Batteries in both key FOBs were just replaced last month so I am assuming that is not causing the issue.
Okay so took It back up to the shop today. We started out by clearing all the codes, no change. So then since the codes directed to the drivers door he pulled the door panel off and verified that all the connectors we connected and fully seated. All connections were good. Still no change in functionality. So made a call up to my service writer at the dealer and explained to him what was going on. He said it is most likely that when they disconnected the handles, with the car battery still connected, that the module lost the calibration/adaptation to the handles. So it should just be a simple re-calibration/adaptation of the system and all should work again. I would like to see if I can't just do it myself and get this done. Only problem is I can't find anything that shows me how to do it with a VAGCOM. Has anyone had to do this after replacing their door handles. I know many around here have replaced their handles themselves. My SW said it would only be about $150 for them to fix it at the dealer, but I would like to have the knowledge of how to do it incase I ever run across this issue again. Anyone have a link to instructions on how to do it?
i searched through ross tech wiki and forums and found no such procedure, which makes me think someone's blowing smoke up yer ***
Hmmm, while I wouldn't normally recommend the dealer... For $150, it might just be easier to pay and have them fix it. With ODIS, they have more options for diagnostics. You're going to be risking paint scratches and all that jazz, pulling handles multiple times, which will out-weight the savings from the dealer if it works, first shot.
I thought I read somewhere when replacing the handles, there are two plugs, and usually they get connected backwards, which is enough to close the loop and not throw a fault, but not correct, thus not function right.
