epc and chek engine light
hello i need help from anyone my q7 suddenly stalls on red light both epc and check engine where on but the car turned on after fine with no problem , while driving one sec both epc and check engine light comes on car losses power and fells like stalling but the other sec comes back up like nothing any tip?
Well you need to read the codes.
Also what year?
Have you checked the spare tire area for water?
Have you checked if your front drains are clogged?
These fill with water and cause random and some not so random fails
Also what year?
i went to the mechanic and took it away from him 2 weeks and nothing its even worse he showed me the last scan he did supposedly with an audi oem scanner he got the following:
05635
01671
01541
01540
01617
01689
01579
05668
its audi q7 2009
Ok thats a vast range of faults which still makes me think water damage or wet components.
do you have the definition for each code i cannot seem to find what they are? i check my spare tire and no water but how do i check the front drains?
I googled these, but like I said they are far ranging and not likely actual faults more like something else is causing ghost failures.I made a video on how to
check front drains. It requires you to remove a few screws on the front tires wheel wells so you can reach up and pull out the drains.
beware though, if they are clogged a ton of water will come flying down onto you lol.
05635 internal control mod failed self test
01671 sensor adaptive cruise control
01541 Lights rise
01540 Lights go down
01617 memory Interrogate interior protection system faults
01689 Electromagnetic dampers suspension manual control valves
01579 seat occupancy sensor passenger
05668 MIL Request Signal Active
some are here some different descriptions but essentially the same
https://sites.google.com/site/1810ma...-01500---01999
01541 Lights rise
https://www.youtube.com/watch?v=CdnFl0ctlBo&t=4s
01541 Lights rise
01541 Lights rise
Knighthawk24
Performance and Tuning
06-11-2015 06:31 AM
MySecondA4
12
01-15-2004 07:29 PM
DirtMonkey_NWB6S4
11
09-19-2001 04:55 PM
