E-Codes Installed...
#11
AudiWorld Expert
i forgot who but (kufatec?) a company sells an adapter for halogen to xenon conversion. a few people have done them on the older Q7s.
#12
Thanks. I've got a VAG-Com cable to help do the reprogramming- if that's all it will need to go from my non-adaptive Xenons to adaptive Xenons. Now I just need to find a set of adaptive Xenons (US or ecode) at the right price. Would I need to do anything special with the auto-leveling?
#13
AudiWorld Expert
i am not sure if any additional hardware is needed for the conversion however on a few other boards members have done the swap successfully. i imagine if you search around through google or through the archives on other forums there would be a diy. unfortunately i can't help.
#15
#16
We're can I get a set of none AFS for an 08?? And I would presume the swap is even simpler with the Non AFS??
#17
AudiWorld Expert
when searching you should make sure you do not purchase the v12 e-codes... they are wired differently since the drl is in the bumper and not in the headlight.
v12:
these are a set i had on my first Q7 with oem bulbs:
v12:
#19
AudiWorld Expert
i don't have them off-hand... they're already installed... depending on which you need there are four different options and part numbers...
#20
Thansk for the response......I have a 2008 S-line with adaptive headlights, so same replacements as you. You don’t have the boxes still that would possibly have the part numbers listed on them? If not, are these Tri-Xenon LED AFS E-Code Headlights on the current 2014 European Q7 as stock equipment?
