EVAP Canister Location??
Does anyone know where the EVAP/Charcoal Canister is located in a 2007--2015 Q7? I have to replace mine as it is leaking fumes but I can't find it for the life of me!
I found it--it's in the right rear wheel well, behind the wheel well liner in the 1G Q7. It's held in there by 3 bolts and has 3 vacuum line connections and 1 electrical connection.
Originally Posted by Brett Eskelson
Hey was this a difficult change? The dealer is saying it will be $1500 to replace it, but I found a new OEM part for only $220 online. It seems pretty simple.
Grey
Hello
I think I have the same problem. When cleaning the canister solved the problem of bad smell?
Had to replace it, change some liquid or parts or simply open and clean the container? I can not find my ... did you have to remove the entire lining of the wheel cellar?
Thank you!!
Thank you!!
EVAP Canister Replacement
S4Alex
NorCal Discussion
09-13-2005 12:28 PM
HACK THS
07-26-2005 02:33 PM
zeus1
01-18-2005 11:39 AM
