Factory rotors
I know you said weight, but do you mean rotor thickness?
Mine just reached 30K miles. I replaced all four rotors with StopTech Slotted (http://shop.achtuning.com/StopTech-1...s-Audi-Q7.aspx) and pads with Carbotech Bobcat. Better grip, no squeal, and no dust. Highly recommend this to anyone considering/needing to change rotors and pads.
StopTech is based in California and they do manufactured from there. They produce several of the big brake kits for Audi. Check their website (www.stoptech.com)
CarboTech is based in North Carolina. They also manufacture from there. I was weighing on Hawk LTS pads but the tuning shop here in Maryland recommended Carbotech Bobcat series. www.ctbrakes.com
I love this set up so much i am thinking about doing the same for my A4.
AudiWorld Expert
Just so you understand. Reducing the weight gives you better unsprung weight which helps handling but in a car the size of the Q7 you loose the ability to absorb heat in braking - going to a lighter disc can impact heavy use of the brakes in mountains and hard driving unless one makes up for it with a bigger diameter rotor and better pads.
