First Auto Scan - 2015 Q7
So ran the first Auto-Scan on our new 2015 Q7 the other night. Car does not have any warning lights on or any real issues, just ran it to get a baseline. Scan shows 5 faults. Since there are no issues should I just clear them and see if they come back or should I do some more digging? Any common issues that would have caused these faults?
Faults Found:
Address 28: HVAC, Rear
1 Fault Found:
01849 - Temperature Sensor for Heated Seat; Rear Left (G94)
010 - Open or Short to Plus
Address 34: Level Control
1 Fault Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Address 42: Door Elect, Driver (J386)
1 Fault Found:
01705 - Selection Switch for Mirror-Adjust (E48)
008 - Implausible Signal - Intermittent
Address 52: Door Elect, Pass. (J387)
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 6C: Back-up Cam. (J928)
1 Fault Found:
9617993 - Proximity Camera
B145C 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Here is the full scan.
Tuesday,15,January,2019,21:16:02:57302
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
www.Ross-Tech.com
VIN: WA1DGAFE9FD030048 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
4F 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE9FD030048 Mileage: 64050km-39798miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0A28
Shop #: WSC 31414 790 00001
VCID: 363524ACA44A80D7747-8062
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number:
Coding: 001378
Shop #: WSC 63270 001 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 3A2D309C9CD264B790F-806E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627793
VCID: 34311EA4B23692C74A3-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902212691
Coding: 0000135
Shop #: WSC 03824 003 1048576
VCID: 2517F3E009ECFB4FCDD-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000030389474
Coding: 000CC026
VCID: 2517F3E005ECFB4FCDD-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0147795236
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0147791274
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133123
VCID: 6E85CCCC9C9AF8177C7-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931514704991
Coding: 290120
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311EA4BEB692C74A3-8060
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0011111
VCID: 270BF9E873E0E95FFF1-8072
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH46 0230
Revision: 10H46000 Serial number: 0038QDA025P6
Coding: 0014131
VCID: 2B0305D86F08CD3F1B9-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME5453034A9
Subsystem 3 - Serial number: 6342QSME5A530366E
Subsystem 4 - Serial number: 6352QSME6A561260D
Subsystem 5 - Serial number: 6362QSME5453305EH
Subsystem 6 - Serial number: 63734SME715929641
Subsystem 7 - Serial number: 63834SME234B3342Y
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026151330286
Coding: 0012152
VCID: 2809FAD47EFEE627F6B-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 F HW: 4L0 920 985 F
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2C00LT5G
Coding: 8BD663040D01CF05020205
VCID: 372B29A8AF4079DF6F1-8062
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M155110B9A
Coding: 00C303
VCID: 3FDB41888770419FA71-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32140445094121971314
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---012 Serial number: 00000000478118
Coding: 0000006
VCID: 6889BAD4BE7E262736B-803C
1 Fault Found:
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 63437 km
Time Indication: 0
Date: 2019.01.07
Time: 09:31:44
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 63964 001 1048576
VCID: 313F17B04D24A7EF215-8064
1 Fault Found:
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 61
Mileage: 63441 km
Time Indication: 0
Date: 2019.01.07
Time: 17:33:28
Freeze Frame:
Error Code: 68
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000149105295
Coding: 00581B00000011110000
VCID: 323D18BC44229CF758F-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 E HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0030
Revision: 00H03000 Serial number: 6PZ 009 014-16
Coding: 0010001
VCID: 303912B4462EAEE72EB-8064
Subsystem 1 - Part No: 4L0 910 568 E
Component: J0770_SWA_Slave_H03 0030
Subsystem 2 - Serial number: 6PZ 009 014-36
Subsystem 3 - Serial number: 5F18.05.1500H03000AMS14006ÿ
Subsystem 4 - Serial number: S14006ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000152669571
Coding: 011F57205E40440004
VCID: 48C95A54D2BE062716B-801C
1 Fault Found:
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 68
Mileage: 63944 km
Time Indication: 0
Date: 2019.01.13
Time: 17:43:11
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82010220430000
Coding: 3569949
VCID: 38292A94AE5E76A766B-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000088375
Coding: 030000
VCID: 290FFFD069F4DF2FE95-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191104139
Coding: 0694221
VCID: 2313EDF807D8057FA39-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H17 0100
Revision: Serial number: 00000000239483
Coding: 0012001
VCID: 5EE59C0C6C3A6897CC7-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000152676107
VCID: 47CB5968DFA0095F1F1-8012
1 Fault Found:
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 63437 km
Time Indication: 0
Date: 2019.01.07
Time: 10:07:27
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156F/0F8271670
Coding: 020007010000000000
VCID: 2411EEE40ED60247DA3-8070
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513FY0F7525045
Coding: 180200060004F9EF710023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130FU0F3367064
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002253923
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000152697173
Coding: 010E57204040230004
VCID: 46D5546CD8AA1057E47-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000370513652
Coding: 0200000000000000
VCID: 313F17B04124A7EF215-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0231842
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E85CCCC901AF8177C7-803A
1 Fault Found:
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 9
Mileage: 63437 km
Date: 2019.01.07
Time: 09:31:37
Voltage terminal 30: 14.2 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H61 0500
Revision: --H61001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C6C4AA860A07523-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: ó
Subsystem 3 - Serial number: RD28.05.15--H61001002F0234ÿ
Subsystem 4 - Serial number: 2F0234ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0152929329----
Coding: 0003595
VCID: 2615F4EC74EAF057C47-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000152697117
End----(Elapsed Time: 02:27, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Faults Found:
1 Fault Found:
1 Fault Found:
1 Fault Found:
1 Fault Found:
1 Fault Found:
www.Ross-Tech.com
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0627793
Coding: 0000135
Coding: 000CC026
Coding: 070000
Coding: 070000
Coding: 0133123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 290120
Coding: 0011111
Coding: 0014131
Coding: 0012152
Coding: 00C303
Coding: 0000006
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 63437 km
Time Indication: 0
Date: 2019.01.07
Time: 09:31:44
Coding: 0015520
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 61
Mileage: 63441 km
Time Indication: 0
Date: 2019.01.07
Time: 17:33:28
Freeze Frame:
Error Code: 68
Coding: 0010001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 68
Mileage: 63944 km
Time Indication: 0
Date: 2019.01.13
Time: 17:43:11
Coding: 3569949
Coding: 030000
Coding: 0694221
Coding: 0012001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 45
Mileage: 63437 km
Time Indication: 0
Date: 2019.01.07
Time: 10:07:27
Coding: 0000032
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 9
Mileage: 63437 km
Date: 2019.01.07
Time: 09:31:37
Coding: 0003595
I've reset my service message with my Hex-V2; works.
Global Autosports
05-09-2012 12:39 PM
gotpressure??
05-01-2005 08:41 AM
