Getting Turn Signal to turn on as White
Not many responses (none) from my previous attempt at getting this answers, so thought I would ask my question a little differently.
So we have a 2015 Sports Edition with the LED turn signals. We have the adaptive headlights and always have the headlight switch in the Auto position. What I am trying to figure out is how to get the LED turn singles to turn on as white with the running lights (like the first picture, only in white) and then also when the headlights are on (like the second picture). I thought they were supposed to turn on with the headlights from the factory but ours don't even do that? Even if they did turn on with the headlights from the factory how do you get them to turn on with the DRL. No matter what position I put the headlight switch in they never turn on white, only light up amber when the turn signal is engaged.
How did the guy in the first picture get them to turn on with his DRLs?
I have the exact same vehicle and it is totally annoying that Audi opted for no front fogs on our vehicles. I will be following this thread and hope someone on this board has a answer.
To my knowledge, there is no way to do what you're asking on a stock vehicle, at least not in the US. I suspect your sample picture has been modified with some kind of aftermarket LED strip that's either always white or has a color-change capability (i.e. LEDs alternate white/orange along the strip). A product like this would do what you're asking: https://www.aliexpress.com/i/32862375107.html. I certainly won't vouch for the quality, legality, or compatibility with your specific car, though.
It looks as though the bottom picture is from a 2009 and lower Q7 as the headlight shape and outer xenon headlamps have the same appearance, also the inner light shape as seen is the round DRL’s that this era of q7 has. You can buy aftermarket LED turn/ parker lamps from ebay etc which allow 2009 and below to have this style of blinker. When the parker lights are switched on or normal driving lights are on the lights will be white then as you turn in a direction one will blink orange as the other one stays white until you stop blinking etc.
As said these lights fit perfectly into a pre 2010 q7 as the mountings are different to the LED versions of post 2009 models.
agree, photo #2 is aftermarket pre-face lift.. photo #1 is post-facelift OEM.
These are not RGB LED's you can change colors, they are DOT Approved lights emitting the right wavelength.. if they could change colors the'd never get approval.
the real question is, why care so much about foglights? I pretty much never use em because it requires disabling the auto on, turning, and high speed dynamic capabilities.
Agreed Dreadlocks. Worse design ever!! Why couldn't they have made it a button to push, like the newer versions! I've had to use them a few times, and I always end up turning the **** quickly over so the headlights don't turn off when driving.
Thanks for everyone's responses. Unfortunately, those were the answers I was worried I was going to get.
Dreadlock, I was trying to find a way that they would automatically turn on with the DRL LEDs that are around the headlights. I agree with you, I would not make any changes that disabled the features you mentioned.
new Ecodes, turn signal melt? i used my original 3 prong turn signal, with the parking lamp.........
pmark837
11-05-2005 01:13 PM
Help! Turn signal stalk is hitting the lower steering column cover (when making left turn signal)...
JKim1.8T
06-02-2003 05:42 PM
Does the E-code turn signal plug (that comes w/ the housing) work with the factory turn signal harne
adammorley
02-23-2002 05:09 PM
Hibiscus Hokie
12-22-2001 12:16 PM
BoBSageT
10-08-2001 10:37 AM
