PR-A8U Safe Function...
AudiWorld Expert
Does anyone on here know what pr-a8u safe function option is?
On my vehicle it is disabled but I am curious what exactly it is.
Thanks.
Thanks.
AudiWorld Expert
hahaha... i enabled it, scanned for codes and nothing came up as "no plausible signal" so i don't think it is hardware related or if it is it doesn't throw a code if it isn't plugged in.
i thought it was pinch protection in the windows but pinch protection works with it enabled or disabled.
On the A8/A6 it is "SAE Rear lights" I have no idea what SAE Rear lights are, but it's what it says the PR-A8U is... Not sure if this helps.. I'm now curious what SAE tail lights are.. Haha
Audi A8 (4E) Comfort System - Ross-Tech Wiki
*Edit*
Also appears to be "No Safe Motors" on the wiki... No idea as to what that could possibly mean.
*Edit*
AudiWorld Expert
okay so we are getting somewhere... SAE is the organization that set the standards for certain parts on vehicles. i wonder if this is supposed to be enabled if you install euro rear tail lights.
The info on this topic is very vague, I also keep reading that it has something to do with anti theft horn? No clue.. On a positive note, there are a lot of threads that happen to be in Russian, German, Etc... That have info for PR-A8U and SAE lighting.. I need to find a way to translate them. There has to be info somewhere online about this. So far the only luck I've had is by searching "PR-A8U" on Google.
AudiWorld Expert
i figured it out... i was able to disable the lower marker lights in the rear by enabling that and disabling NAR setting.
central convenience II
byte 2
bit 3 north american region disable
byte 2
Interesting! I wonder if that could be done on a 2008 model. are you going to leave it turned off? It would really clean up the rear end at night, especially once you do e-codes.. :-) I need to get my self a VCDS.. Haha! Don't wanna get off topic, but what's the cheapest VCDS cable?
AudiWorld Expert
yep, i am leaving them off. coincidentally it also removed the front marker light as well which i was trying to figure out earlier by changing the regions but it was in a different module.
i only purchase authentic items and directly from rosstech. they're the best source and offer support in case you botch up the coding or need help learning a new platform etc.
Ross-Tech Store: VCDS
Just did this on my 2010. Great finds. Initially when i read this thread i didn't care much for it, but having done it, the Q definitely looks cleaner from the back at night without the bumper marker lights. Same goes for the orange lights on the headlights.
One thing to note: On my 2010, its actually byte 1.
