How to re-align windshield wiper arms?
The windshield on my 2015 Q7 was replaced earlier this week, and it seems the independent shop didn't get the wipers back in the original position. When parked, they're now quite visible above the hood line. The passenger side arm now travels way too far (the tip comes all the way into the driver's line of sight), and it's just generally not right. I tried manually pushing them down lower, but the computer brings them right back up again when power is turned back on.
No doubt I'm looking at opening up the wiper arm caps and rotating the arms on the spindles, but is there a trick to the process or to getting them lined back up properly? Yes, I could take it back to the glass people, but I get the impression they hadn't seen many Q7's before, so I'd rather just do it myself.
Ultimate Keyboard Warrior
I had a similar issue when Safelite replaced my Q7 windshield at work. Noticed it after the fact, stopped by their place of business on the way home from work. The tech knew right away what was wrong when he saw I had an Audi.
He took it to the service bay and had it fixed in about 10 minutes.
Not much help for you--just stating the tech knew how to fix it. Said VW same way.
the wiper arms look like they lock into the motor drive shaft with a square fitting. that doesn't leave many options for re-clocking. Does the shaft also come off too?
I've done this before on other cars where the wiper and shaft are both splined, which makes it easy to realign. Not the case here, unless I'm missing something obvious.
I am having this exact same problem. Seems like there should be a way to reset it somehow, why would they get missaligned anyway... I did look though VCDS, but didn’t see anything for adjustment, besides putting the wipers at their beginning and end reach points. Were you able to realign the wipers? Did you end up pulling them off for realignment?
Definitely not in service mode...that brings them half way up. They are up by maybe a cm or so. It’s off just enough for the driver side wiper to slap the side of the windshield when all the way up.
