How to replace the front door speakers.
The front door speaker started rattling and progressively got worse. A portion of the foam surround had disintegrated due to water dripping inside the basket holding the speaker. I priced the replacement and it was between $71 - $100. I decided to purchase the foam surround which only cost $8 and some .
You will need a T-25 Hex to remove the bolts that hold the door panel. The speaker basket also has them but the thread pitch is different.
You will definitely need this to avoid damaging the panel and trim.
Nylon Pry Bar Installer Kit
There are 4 bolts holding the door. I marked them with yellow arrows.
To gain access to the bolt behind the wood grain trim piece you'll start prying it carefully from the left, closest point to the latch.
Once you have removed the bolts begin prying the panel starting from the bottom. Disconnect the cable from the inner door handle and the control module connector.
Here is the door without the panel.
In case anyone needs the part number for the control module it is: 4F0959793R (my car is a 2009)
cmk1523
05-03-2022 04:30 AM
Methodmayhem
06-20-2002 03:57 PM
Doctor Steve
05-15-2002 01:00 PM
