Install hitch on Q7 with panoramic roof?
#11
I agree with the bad info suggestion. I have the panoramic roof and factory towing. Dreadlocks has it right about getting a factory package and not losing out on all the automated intelligence baked into the vehicle.
Just went car camping a few weekends ago with a rented travel trailer and plenty of gear. Total trailer weight was over 6000#. I wasn't blazing up the mountain but, given 30s or so, could still pass semis and slower class A and C RVs. I wasn't hearing any creaking or groaning from the vehicle either on the road or while parking and pulling out from the campsite.
#12
Thanks everyone. When I get a chance to take off the rear bumper cover, I'll report back with what I find. In the meantime, I'm investigating how to remedy the creaking panoramic roof...thankfully I won't be towing with this rig as I can see it becoming even worse with some lateral stresses on the frame.
#13
You can just try cleaning all the seals with a silicone based spray and see if that cures the noises.
I fitted an aftermarket towbar with factory electrics and a Pano roof with no issues.
I tried in vain to find out why Audi do not recommend fitting a tow bar with a Pano roof and there is no further information available. I suspect they had some leaks on early test cars and put it down to increased flex in the roof when loaded up and on uneven ground.
#14
I think I recall seeing that a weight distribution hitch is not recommended, perhaps the unibody and hitch wont like the distribution forces put through the hitch?
#15
Does anyone have the part number for the OEM electronics kit? I too think it is silly to pay 900 for a tow hitch when a 150$ curt will be fine hardware wise, but I do want the factory configured electronic goodies though.
#16
Cheaper to buy the hitch kit, they installed a curt hitch w/no wiring on mine.. I demanded wiring and it cost em $1100 for the tow module and wiring kit, whereas the whole tow package was on ECS Tuning for ~$800
#17
good to know. hoping to use some of that bosch money to do this.
do you perhaps know the part number or the trans oil cooler and lines so I could retrofit the tow package onto our Q?
#18
I bought the Curt hitch, the control unit from a wrecked Q7 in a junk yard, and the wiring here: https://cars245.com/en/item/audi-vol...1124F-harness/
$460 total.
$460 total.
#19
Thanks Hoosier.
anyone know if this control module number which a guy used on an 11 will also work with a 13?
4E0907383J
Also, do I need to run any wires to the rear? Vehicle has no hitch or prep package.
Thanks,
4E0907383J
Thanks,
#20
I believe that part # works up to 2015...it's just the revision that changed (B,C,D,etc instead of the J). I think you need the electronic brake controller if you don't have the tow prep installed from the factory.
