Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Jack Mode / Removing air suspension compressor
Old 12-28-2015, 05:24 AM
ouroboros's Avatar
Default Jack Mode / Removing air suspension compressor
Hi,
At the same time as searching for an air leak I'm contemplating servicing my Q7s air compressor. I have a question about jacking and jack mode in this scenario. I'm aware jack mode is needed to lock out the suspension during normal jacking. However does anyone know what happens when you remove the compressor? I.e is the locking mechanism physical or locked by air as I'd like to know if the car is likely to drop when I remove the compressor?
Best regards,
Old 12-28-2015, 02:18 PM
smith2010Q7's Avatar
Call these guys. They can answer your question.
https://www.arnottindustries.com/par...17_pid166.html
Old 01-21-2016, 09:34 AM
ouroboros's Avatar
It ended up being my front right shock which I replaced with one of Arnott's by a good local independent. So far so good.
In the end the air leak wasn't that hard to figure out. My compressor could still pump up the front shocks and the one that decreased first was the leaking one.
Re compressor replacement: You *definitely* need a professional full car lift as the suspension system will drop when you release air from the system and the compressor is underneath the car. A repair that should be done by the professionals on such a large car.
jaypines
Q7 MK 1 Discussion
13
09-08-2017 06:29 PM
Gani
Q7 MKII Discussion
06-30-2017 12:54 AM
dotrenrew
Audi allroad
17
08-03-2013 06:29 AM
mendelo
Audi allroad
36
02-23-2013 02:37 AM
BobsA4Q
Audi allroad
9
05-14-2008 03:06 PM
Quick Reply: Jack Mode / Removing air suspension compressor
