Q7 MMI Board Replacement
Hello,
I am looking to replace my MMI board after some coffee was spilt on it. My board has a P/N of 4LO919609M, this board is a 4 button. I found a 8 button out of China from a link on another posting from this forum...my question is, would the 8 button work with the 4 button configuration...I just would not be using the additional 4 buttons. Other than having a 4 more buttons, they look the same...thoughts?
See attached jpg's
Best - Andrew
See attached jpg's
Best - Andrew
I highly doubt a 8 button circuit board will function the same as a 4 button circuit board, even thought they're physically the same. You might be able physically swap it out. There's got to be logic in the board that allows 8 button functionality which will be completely different from the 4 button version.
I'm just thinking from an electronic perspective. The physical aspect might be the same because the MMI is physically the same across different model years. But your controllers and other electronics get upgraded.
-ThinkMac-
-ThinkMac-
-ThinkMac-
-ThinkMac-
PJS4
10-13-2000 05:58 AM
