New Q7 Issue - Engine Light, Lift Fault & ESP Warning
#11
What's odd, is if the battery was failing i would think it would have failed by now. It's been starting like this for 4 months. Who knows though.
#12
If you have a vcds cable you can do your own battery, Albeit it’s under this driver seat! Just make certain to buy one on the list that the ECU will except.
also you’ll want to Google the vcds battery replacement, should find you the procedure.
#13
Anyhow!
Wait- you can program the new battery in with a HEX-V2 VCDS?? I didn't know that was possible with the $200 tool. If so, is there a write up anywhere on how to do it with the HX-V2? I'd MUCH rather do this myself- Paying a mechanic to replace a battery seems asinine.
~George
#14
You need a set of , A Torx wrench, and a VCDS, I have a Hex-COM from ~2001 and just did it fine.. Took 15-20mins including finding the tools since they were not put back the last time heh.
#15
#16
The worst. My d3 started throwing wierd codes had to take it to Audi to get a battery. 500 bucks later new battery no more codes. I'm still dealing with p2179 which I believe is a vac leak.
WhiteOut69
15
04-01-2019 11:33 AM
ltooz_a6_a8_q7
09-25-2012 05:27 PM
schalliol
05-17-2012 08:02 PM
EuroVWGTi
10-19-2009 11:16 AM
allroadbryan
Audi allroad
05-25-2005 05:58 AM
