Not sure how Advanced Key works on my 2008 Audi Q7
First off the remote fob works fine(Unlock, Lock, Open Rear Gate etc....) but .....with the key in my pocket,
I can only lock my doors if I push the button on the Drivers Handle, when I push the button on the other handles it does not lock, are they supposed too?\
The doors unlock when I approach the Drivers Side door. The other three doors, unlock if pull on handle once and pull again. Is this the way they are supposed to work?
Also below are the only Fault codes I am getting for the doors. I have research my owners manual and other websites without any luck, any information would be appreciated.
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0051915
Shop #: WSC 31414 790 00001
VCID: 2F6A8B93BE0EEB46F4-807A
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 122370 km
Time Indication: 0
Date: 2018.12.14
Time: 15:39:26
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0051722
VCID: 316E8DEBA83AFDB6E2-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 122370 km
Time Indication: 0
Date: 2018.12.14
Time: 15:37:35
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 122370 km
Time Indication: 0
Date: 2018.12.14
Time: 15:39:26
Coding: 0051722
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 122370 km
Time Indication: 0
Date: 2018.12.14
Time: 15:37:35
When you have the key in your pocket, all doors are supposed to be able to lock the Q7 by pressing the button on the door handle. All doors should unlock the vehicle by simply touching the handle. If you have to pull the handle - twice- in order to unlock, this indicates defective sensors in the handles. This is chronic and apparently happens due to water infiltration. Our 2011 had one handle that would not lock the car and our 2015 had 2 when we got it. I had those replaced under warranty. It’s expensive because it requires painting the replacement handles.
I’ve seen that too. Mine was warranty and dealer says they always do the whole handle. If doing it myself I’d be tempted to try a sensor replacement. I think the sensor and the switch ( button) are separate though.
silvertiger
02-28-2002 04:53 PM
Richard Solomon
02-04-2002 01:47 PM
