Oil consumption?
Oil consumption?
OIL CONSUMPTION! Every 7000 miles from oil change my 3.0 TFSI needs a quart, but not 300 miles earlier when I checked it last! WTH? Where does it disappear to all of a sudden? I mean, I pretty much drive like a grandpa! seriously. Audi tops it off, no worries, but my Yota never did that, with 290,000 miles on it! Yours?
Got my A8 about a month ago, topped it up after 2 weeks , and now the warning is back on. 1000 miles. I’m at 58 K. Car is still under Carvana warranty, this should be covered, right? And I should take to an Audi dealership? 3.0 T btw.
Audi says oil consumption, even heavy use, is totally normal for superchaged engines! I call bullsh*t! But most all Audis do.
I am abusing oil at almost 600 miles to add.
I was hoping that the flush and different oil and additives would help. I may just as well switch back to castrol.
Well, that is something you will have to speak to carvana about.
jbgilbank (09-13-2023)
It can leak, you may have bad pcv valve (run vcds scanner to see errors). But really seems normal according to the owner's manual.
I would dream to have your consumption.
Technicians warn against capricious 3.0 tfsi and advise to run away from it.
This was a great explanation and understandable! And he is right, although I do love this car, I would not own another, I don't believe.
The problem should have been addressed by the manufacturer. It really is unacceptable as far as quality standards go, for Audi/VW/Porsche to produce engines like that.
jbgilbank (11-06-2023)
d4m0n
A4 (B7 Platform) Discussion
17
07-03-2007 01:28 PM
MySecondA4
10
03-02-2004 07:46 PM
