Q7 4.2 FSI Squeaking Noise
Hi all
I've having squeaking noise trouble with my 2007 Q7 4.2 FSI.
[Noise on YouTube]
[Noise Occasion]
-Start up and cold temp: NO ISSUE
-Temperature goes up to the middle of temp gauge: Start squeaking
-The noise goes away when revving up.
-Noisy at idling to 2,000rpm (2,000rpm or above go away)
[Parts I've changed]
-Tensioner Pulley
-Idler Pulley
-Accessory Belt
[Status]
Still having noise issue…
Your advise will be greatly appreciated!!
Thank you
[Noise on YouTube]
[Noise Occasion]
-Tensioner Pulley
-Idler Pulley
-Accessory Belt
[Status]
Thank you
nicely done. I had posted that up awhile back and had the exact same issue as you could hear that squeal from blocks away. The dealer keep thinking it was a pulley or something and had no idea.
Finally had a Mercedes buddy narrow it down and I took it back to the dealer where it was the fuel regulator if that is the same part #
Thanks for the comments guys!
My total expense for this work was:
<Expense from Correct Diagnosis>
-PCV Valve $218
<Expense from Incorrect Diagnosis>
-Tensioner Pulley: $140
-Serpentine Belt/Accessory Belt $30
-Idler Pulley $35
Total $423
-PCV Valve $218
-Idler Pulley $35
Total $423
