Replace HID bulb with LED?
Has anyone tried this on the Q? My HIDs are starting to go pink and I thought that LEDs would be brighter, ignite instantly and maybe would last longer.
Would be interesting to see if this is plug and play. I installed LED bulbs with power converters on my friend's GLI, which had halogens. The look was amazing and so was their pure white color. Didn't throw any bulb error codes either.
My guess is it should work, just need to make sure you get the D1S/D2S fitment and make sure they come with a small ballast that eliminated the bulb out error message
I would not replace HID's with LED that is going backwards...
LED's presently can not be brighter than HID, also the LED's for headlights get quite hot so they have fans on the back of them which makes it impossible to now enclose the headlight assembly as the FAN assembly hanging off the back sticks out too much AND it needs air flow, so even if you could get the rubber backing to close it cant cool itself.
HID's are cheap, just check amazon. I replaced mine with 8000k's I think under 20$ each.
I did replace my Daily driving lights with LED bulbs though, their resistors for can bus always fail the first check so I get annoying lights out warning till it checks again.
Oh well, i'll live.
Oh well, i'll live.
Oh well, i'll live.
Oh well, i'll live.
Thanks again.
captdave311
09-08-2011 08:08 PM
Noodles
Audi Original "S" Cars
03-21-2007 09:49 AM
98a6quattro
09-25-2003 10:22 PM
