Squeaking noise from left rear
When the car is stationary and I rock it from the left rear it creaks and squeaks. Doesn't do that for the other 3 tires. It also makes a loud grinding sound at very low speeds. I removed and reinstalled the rims a couple of times and the issue is still there. Gonna take it to get checked out soon, do you think it's a suspension issue? 2013 Q7
Could really be all sorts of things. It is possible you are also looking at multiple issues. The squeak is likely a bushing issue or sway bar linkage. I would start there. Grinding while driving could be the same thing, especially if the bushing is in really bad shape and the weight of the vehicle is causing significant metal on metal contact but it could also be a bearing or brake issue that is potentially separate and distinct from the other squeaking noise. Will be curious to see what you find!
KillA6
13
04-04-2007 10:39 PM
Tostao
04-12-2004 04:31 PM
