TDI EPA Fix Completed
#371
They are giving me a loaner. Particulate filter part needs to come from Germany. May take a week or more. SA says particulate filter typically checked at 120k miles, so this is early. I said that I've seen other folks (i.e. here) talk about this as an early issue. He says oxygen sensor is more typically first thing to pop up.
I asked whether particulate filters could be changed more pro-actively. They say my style of driving (i.e. short local trips - especially in winter, car doesn't warm up) is contributing to the issue. Not much I can do with my daily commute to the pool. :-)
#372
We drive ours on most of our longer trips. Hopefully we will avoid this. I have heard the cooling fans run after shutdown from a short trip. Indicates an incomplete dpf regen.
#373
We too had a CEL recently. 12 months 15000 mi since the fix. Q7 needed a new AdBlue injector pump. Turns out there is a TSB for some that had the AdBlue filter installed improperly on the pump. Ours was one of those. Tech found the filter dislodged in the AdBlue tank. Pump had been pumping unfiltered AdBlue. One day to get part. Ready following day. No biggie. Running great. Good fuel mileage. Throttle response improved. Is that connected? No idea. Maybe they did a throttle body reset.
I also had a CEL light came on couple months ago. It was an oxygen sensor on the passenger side went bad. The dealership replaced under warranty. They also mentioned that CEL on have 2 kinds. One is on steady and the other is on and flashing. On and flashing is more serious situation and needs prompt care. Mine is steady on so I wait for an appointment to do it.
#374
My CEL has come on three different times since the "fix". Each time I've cleared the DTC's with the Vag-Com unit and it runs again without a CEL for many weeks. When it does come back on, it's after a bunch of in town low rpm driving.
If you're curious, this is the readout of the last time the CEL came on:
They were cleared again, and I've been driving with no CEL since.
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA H23 0012
Revision: 54H23--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 50949 002 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 2240FA403516B35AE3-8076
2 Faults Found:
16871 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 100331 km
Date: 2019.01.11
Time: 06:16:25
Engine speed: 1773.50 /min
Normed load value: 47.5 %
Vehicle speed: 73 km/h
Coolant temperature: 71 °C
Intake air temperature: -2 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.320 V
Unlearning counter according OBD: 40
Exhaust gas jet volume in particle filter: 493.1 m³/h
Particle filter: difference pressure: 139 hPa
Particle filter: soot mass measured: 24.15 g
Particle filter: soot mass calculated: 5.54 g
Exh.gas temp.sen 3: 633.5 °C
Exh.gas temp.sen 4: 590.0 °C
17277 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99598 km
Date: 2018.12.20
Time: 15:55:03
Engine speed: 1654.50 /min
Normed load value: 82.4 %
Vehicle speed: 68 km/h
Coolant temperature: 96 °C
Intake air temperature: 12 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 14.520 V
Unlearning counter according OBD: 25
SCR efficiency test overall: 42.90 %
SCR error threshold of efficiency test: 45.00 %
SCR efficiency test 2: 0.437
SCR efficiency test 1: 0.413
Particle filter: unburned fuel calculated: 0.003
SCR catalytic converter average temperature: 270.8 °C
Long-term adaptation of reduction agent dosage: 1.06
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100331 km
Date: 2019.01.11
Time: 06:16:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99598 km
Date: 2018.12.20
Time: 15:55:03
#375
Funny. I had forgotten how long the warranty was. 40k or 50k? I did look it up (50k/5 year) when I came home last night with 39,949 on the clock and a 55 mile drive to the dealer. I am happy to get this fixed under warranty.
Interestingly they said the little-black-square door lock button/mechanism on the passenger side was ‘out’. $500 to repair. Since I never lock from the passenger side, I had never noticed. Frankly, I use the fob to lock. But, I also asked why warrantee wouldn’t cover that? They are checking.
The loaner 2018 Q7 with Driver Assistance package is interesting. First time using DAP. Jury still out.
#376
I don't know that I would worry about the touch-sensitive door handle. In my experience, it is just going to fail again. Additionally, it isn't something that has a large impact on the overall functionality of the vehicle, so why bother throwing good money after bad?
I had my front passenger door handle replaced under warranty during the float period of the settlement back in 2017. At this point, it is the only handle that works consistently on the car (it worked then like the rest work now!). I have just adopted the habit of actuating the locks using the fob or, occasionally, just using the flip key.
Oh, and if you're talking about the 'fix' warranty, a simple interpretation is that it only covers emissions system and anything related to CEL illumination (e.g., drivetrain items).
#378
Oh, yes. If you are still under original warranty, then yes, it should. I'm at 81,000 miles on mine, so well outside of that.
This was fun last week, though....
Well, I guess not. It acts like I can upload photos to insert in posts.... but apparently not.
#379
Hi, I had an oxygen sensor error code came out last August. After took it in to check and replace the sensor. It has been warning-less until now. The same sensor error code come out.
I just took the car back to the dealership.
Anybody had the same issue?
#380
Since the VW Diesel "Fix", the following error codes have popped up intermittently. I clear the DTC's and they stay away for many miles and a long time (over 4 months since the last one) before reappearing - at which point I clear them again. So far, so good.
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100331 km
Date: 2019.01.11
Time: 06:16:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99598 km
Date: 2018.12.20
Time: 15:55:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 100331 km
Date: 2019.01.11
Time: 06:16:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99598 km
Date: 2018.12.20
Time: 15:55:03
