Tire pressure OEM 21" wheels/tires
The max tire pressure is 50 psi. I up sized my 21 inch tires on mine, but I have them put 38 psi in mine and rides great. This link show max pressure and it’s stamped on the sidewall. I will check my manual when I go out.
https://www.discounttire.com/buy-tir...p-zero/p/42199
If you roll the pressure at the OEM specs, you're going to be replacing tires pretty fast. I have mine at 50PSI, to combat the wear and gain better handling; I use my air suspension to make up the comfort difference. Watch the edges of your tires for the next few thousand miles, and note the feathering that happens on the outer edges, with the lower PSI.
uberwgn (07-01-2019)
I will try the factory settings listed for the newer Q7 that run that size, see how it rides.
Lozano4281 (08-16-2019)
