TPMS/ABS
2 days after I had my rear passenger tire was repaired my TPMS and ABS warning lights came on, at first they would be on and then shut off then stay on for a couple days and then shut off. I have a 2014 Q7. Any ideas?
reset the tpms in the mmi, needs to recalibrate the size.. did they patch it or did it require a new tire?
Originally Posted by dreadlocks
(Post 25332516)
have you, well checked the tire pressure manually?
If both the TPMS and ABS light are on it very likely nothing to do with the tire repair or just TMPS. It is more likely an issue with a wheel speed sensor, since both of those systems need to know the speed each wheel. Could be coincidence or it could be the service garage damaged the sensor wire.
