TPMS and Air suspension
I am considering purchasing an Audi Q7 and was told it has the following issue. The TPMS warning light will come on but all tire pressures are within spec. When this happens the air suspension stops working. If you turn the car off and back on the light turns off and the air suspension starts working and it will stay working for several days. Any thoughts?? If this matters, the vehicle is a 2011 S Line Q7. Thank you!!
If you are in the USA, the 2011 Q7 would not be fitted with in-wheel sensors.
Are you buying from a non-Audi dealer?
Yes, I am in the States and it is a non Audi dealership. It is a little too far for me to just check out unless I am seriously going to by it. I currently do not own a Q7 so I apologize if me assuming it has this I was wrong. What he said was that the warning light for low pressure would come on. He checked all the tires and the pressures are correct. When you simply turn it off and back on the warning is gone and the air suspension is working. This happens without him having to reset anything.
What warning light comes on? The amber flat tire light, or an up and/or down arrow superimposed on a car? TPMS error would not keep the suspension from working. There are other issues that will though, ride height sensors, residual check valves, air valve/manifold, air compressor, etc.
Musolmaz
06-17-2019 04:08 PM
Small Town Terrorist
Audi allroad
03-20-2007 06:04 PM
