VagCom Changes and Modifications MMI-3G+...
#11
I noticed in my DIS this morning that along with lap timer there was oil temp (active) and boost gauge (inactive). Has anyone actually been able to monitor boost through DIS? I couldn't figure out a way to make it work.
#12
Icono,
I have enabled the battery meter but I don't recall exactly how I did it. I know for a fact that I did it through hidden menu assuming you've done this already too.ill play around with it tomorrow morning and report back
#13
AudiWorld Expert
If i recall correctly your Q7 does not have MMI-3G+ so it is a bit different. I was able to do it in the past just not on the current one with the newest MMI unit.
#16
Audiworld Senior Member
DVD Override is called VIM Vehicle In Motion
The directions listed here work on all models (including my 2014 Q7): http://www.audienthusiasts.com/VagCom.html
#17
AudiWorld Expert
A complete list of instructions and options for Q7 2g, 3g and 3g+ MMI:
stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - Audi Q7 4L - VCDS Codierungen, Webdesign
#18
AudiWorld Expert
Comfort Convenience Via Remote (Windows Open Through Remote):
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
http://trick77.com/tools/mmi3g_vimcode.php >>> Video In Motion VIM MMI-3G & MMI-3G+
quattroworld.com Forums: Seatbelt Chime + Airbag Warning Light... >>> Additional VagCom / VCDS Changes.
quattroworld.com Forums: VagCom / VCDS Changes & Modifications...
AudiEnthusiasts Master >>> General VagCom / VCDS Coding (Mostly B8 & 8R but some changes and tweaks apply to the 4L)
Audi Q7 (4L) - Ross-Tech Wiki
Entire VagCom / VCDS Catalog Of Changes, Upgrades & Modifications:
stemei.de .Fahrzeugcodierungen .Codierungsservice .Webdesign - Stefan Meier - Audi Q7 4L - VCDS Codierungen, Webdesign
Bit 2 - Set to 1
#19
AudiWorld Expert
VagCom Changes:
- Lowered 10mm Front & 15mm Rear
- Current Gear Supression Disabled
- Immobilizer Active
- Disc Brake Wipe Enabled
- Hill Hold Control Enabled
- Camera Speed 20KMH
- Gauge Needle Sweep Enabled
- Lap Timer Enabled
- Boost Gauge Enabled
- Oil Temperature Enabled
- Shift Suggestions / Economy Mode Active
- Fuel Door Unlock Via Driver Door Button
- Long Press Window Functionaliy Enabled
- Emergency Brake Indicator Enabled
- Brake Amplification Enabled
- Ambient Lighting Disabled
- Interior Door Handle Illumination Disabled
- Comfort Opening Front Sunroof Enabled
- Automatic Wiper Park After Ignition Off Enabled
- Highway Light Function Enabled (90mph+)
- Adaptive Light Activation 20% Earlier Enabled
- Seatbelt Warning Disabled
- Key Warning Disabled
- Brake Pedal Engagement Warning Disabled
- Start Note Disabled
- SAE Rear Lights Enabled (Rear Marker Disabled)
- SAFE Functionality Enabled (?)
- Pinch Protectin Enabled
- Video In Motion Enabled
- DVD/CD Ripping Enabled
- LED 100% (DRL & Headlight w / DRL)
- Hill Hold Assist Early Engagement
- Lap Timer Enabled
